Old 01-13-2018, 06:51 PM
chris slawski chris slawski is offline
Default 69 Muncie side cover
Hello folks
For a 69 Nova which is the correct side cover for full functionality, ie neutral safety switch, and if I have a 68 dated trans would there be any other recommended functional updates. I am not a 100 % numbers guy for this car just want correct look and everything to work as it should factory wise.
Thanks!
Old 01-13-2018, 07:36 PM
L78steve L78steve is offline
There will only be a switch port on 70 up Muncie side covers.
The neutral safety switch is on the column on your 69.
Your 68 trans if fine as it is for 69.
The Following User Says Thank You to L78steve For This Useful Post:
chris slawski (01-13-2018)
Old 01-15-2018, 03:49 PM
Zman1969 Zman1969 is offline
69 had a "306" casting cover and the shift levers were retained by 3/8" bolts 69 had a stud with fine thread nuts
heres cover on the auction - not mine
https://www.ebay.com/i/263333954932?chn=ps
reverse shaft is incorrect in the picture
69 RS/Z 302 VE3 Daytona
69 Chevelle SS 396 375
69 T/A clone LS6/6 speed
90 Formula 350
