Old 03-26-2018, 10:53 PM
Default R59 Date Code Deciphering
Used to know these codes. Little help? J71.....................................10
Got to be in the mid 70s based on warranty sticker dates.
Attachments - The Supercar Registry 46743300-071D-49C2-936A-E4C4641C12FA.jpeg 39F8CC49-821C-4F5A-9F2E-3F5A82AD8451.jpeg 05D5F7E9-9C64-4BCC-9765-7B8C7B80B829.jpeg
Old 03-26-2018, 11:10 PM
Steve Shauger's Avatar
Administrator
Sept 1977 built at the Anderson Indiana plant. It was not assembly line because it was shipped dry, so it was a replacement battery.
www.yenko.net
www.vintagecertification.com
mockingbird812 (03-26-2018)
Old 03-26-2018, 11:14 PM
Got it Steve. Thanks - figured you’ve seen a few of these. How do these score in judging relative to the repro batteries?
Old 03-30-2018, 09:45 PM
As Steve referenced,and to add,that's not the number 1 after the letter J,but the letter I for the Battery plant code.
Some Delco plant codes I've recorded:
I=Muncie,Ind.
C=Anaheim Ca.
G=Fitzgerald,Ga.
K=Olathe,Ks.
N=New Brunswick,N.J.
R=Korea
Z=Oshawa,Canada
The Letter I was not used to identify the Month,but it was for the Assembly Plant.
10 is the day this battery was made.
Old 03-31-2018, 01:40 AM
I=Muncie,Ind.
C=Anaheim Ca.
G=Fitzgerald,Ga.
K=Olathe,Ks.
R=Korea
Z=Oshawa,Canada
Ah, love the details Rick - thanks. The casing at the bottom states that the battery was made at the Anderson Indiana plant - is that in Muncie? So, if this stamping is near the bottom of the case, why is there a code with the same info on top of the case?
Old 04-03-2018, 01:12 PM
Anderson Ind. is their production plant where they produced the battery casing.
Muncie Ind. is where all the parts came together to make it a working battery.
mockingbird812 (04-03-2018)
Old 04-03-2018, 01:45 PM
Thanks Rick.
