Old 12-14-2018, 08:49 AM
chevyman0429's Avatar
chevyman0429 chevyman0429 is online now
Default 1969 chevelle body to frame bushings
Can anyone tell me the difference between buying a hardtop set of body bushings to the convertible set! Also any recommendations on who sells the best set. Thanks
1969 SS 396 chevelle
1978 chevy shortbed step side
1983 chevy shortbed
1985 chevy shortbed
Attachments - The Supercar Registry tn_IMG_5907.JPG tn_IMG_5906.JPG tn_IMG_5903.JPG tn_IMG_5901.JPG
Old 12-14-2018, 09:19 AM
Woj's Avatar
Woj Woj is online now
I believe the convertible has two more bushings vs the hard top.
Ground up sells a nice kit with the fasteners: https://www.ss396.com/chevelle/DCC-1...hevelle&year=0
Old 12-14-2018, 11:02 AM
Ryan1969Chevelle's Avatar
The kit I bought required me to buy several additional bushings..... if I did it again I would buy individuals. (The Ground Up Kit May be the way to go)
Check out my thread as Cutlass has very few bolted bushings.
Ryan W31
Old 12-14-2018, 02:03 PM
AutumngoldL78 AutumngoldL78 is offline
The vert kit has two extra bushing that goes towards the front.
Old 12-14-2018, 02:40 PM
novadude novadude is offline
Yes. Under the cowl - the ones that are visible in the engine compartment.
Old 12-15-2018, 01:13 AM
Well both my hardtops have a body bushing on each side that’s visible from under the hood with the inner fender wells out!
1983 chevy shortbed
1985 chevy shortbed
Old 12-15-2018, 02:35 PM
SS427's Avatar
SS427 SS427 is offline
The frames are the same as far as the front and rear halves go. Only the center sections differ between the coupe and convertible and both have two front mounting locations in the frame (see photo). However, the coupe only uses one of those mounts (the outside one) whereas the convertible incorporated both (see photo of convertible body on frame).
Rick Nelson
Old 12-15-2018, 02:40 PM
SS427's Avatar
Similarly, the rear sections are also the same between the two cars. The couple (1st photo) does not use this mount whereas the convertible (2nd photo) would use this solid mount in addition the rest of the coupes mounts.
Rick Nelson
Old 12-16-2018, 11:14 PM
Exactly the info I was looking for thanks!
1983 chevy shortbed
1985 chevy shortbed
