Old 08-30-2020, 02:16 PM
Crush Crush is offline
Default Paint reading and thickness
What brand is best for measuring paint thickness and what numbers should I expect on each panel? Do cars of the 70’s, 80’s &90’s all have different thickness? Repainted panels will have higher readings? Do cheaper devices read as good as the more expensive?
Any other thoughts?
Thx in advance
Bary
Old 09-01-2020, 11:26 PM
Any thoughts?
Old 09-01-2020, 11:56 PM
I have a Fender Splendor paint thickness gauge but I've only used it once, on a 1970 Chevelle SS. Most of the paint on that car was .0025"-.0040 thick", the stripes were .005"-.006" thick. This is the only gauge I've ever used so I can't speak about other thickness gauges Crush.
The Following User Says Thank You to carnut4life For This Useful Post:
Crush (09-02-2020)
Old 09-02-2020, 12:22 AM
Steve Shauger's Avatar
Administrator
I recommend the Fender Splendor as well. I have FS488 which has been trouble free, with repeatable readings. There are variations with the different applied paints and technology. The key is consistency throughout the vehicle. Big variations may indicate repair.
www.yenko.net
www.vintagecertification.com
Crush (09-02-2020)
Old 09-02-2020, 01:06 AM
L16pilot L16pilot is offline
Exactly what at Steve said...consistency is the key. I use a relatively inexpensive CEM brand device...probably stands for China Electronics Mfg...or something like that...but it is consistent. On GM lacquer vehicles, I typically find between 3-5 mils on original finishes. It's when you start measuring 7+ that sends up red flags. Can't speak for Mopar or Ford as to typical original paint thickness to be expected.
Steve Nuwer
1970 Z28, Norwood 03A, 48 48, 723 Int, M20, COO, 2021 Legends Platinum restored
1970 L78, Norwood 04C, 17 17, 711 Int, M21, COO, born-with drivetrain project.
1972 Z28, Norwood 11C project, born-with drivetrain, 26 26, 775, M20, CGG project
1970 Z28, Norwood 05C, 48 G, 720 Int, M21, COZ, Original Unrestored (SOLD)
www.2ndGenZ.com
The Following User Says Thank You to L16pilot For This Useful Post:
Crush (09-02-2020)
Old 09-02-2020, 12:54 PM
SS427's Avatar
SS427 SS427 is offline
I also have the FS488 Fender Splendor and have been using it on my inspections for the last 5 years or so. Totally trouble free and accurate. Its been a great tool.
Rick Nelson
The Following User Says Thank You to SS427 For This Useful Post:
Crush (09-02-2020)
Old 09-06-2020, 06:56 PM
Stefano Stefano is offline
You can purchase paint measuring devices which cost thousands of $$$$. I have been using Fender Splender brand without issues for many years and they cost much less.
