Old 06-03-2021, 12:46 PM
dmarr35 dmarr35 is offline
Default 1969 camaro brake booster to master
Is there anything between the Master and the Brake booster o ring or something I am having a vacuum loss in the booster all new I will look in back of Master and check the booster seal without applying the brakes with a vacuum pump I lose vacuum in the Booster Thank You for any help.
Old 06-03-2021, 01:50 PM
m22mike's Avatar
m22mike m22mike is offline
Rubber cup seal
Old 06-03-2021, 01:54 PM
Thank You that is what I thought so I will look gasket and look for a rip if not I most have a Bad Booster
Old 06-03-2021, 02:48 PM
m22mike's Avatar
There is also a small "O" ring on the metal pin that goes into the booster.
What is the history on this booster ?
