Old 06-27-2021, 03:05 PM
XXXGoldL34M20's Avatar
Arrow Hoard of 1970 1971 1972 Chevelle Cowl induction Parts
A hoard of Cowl induction parts see updated list above with prices.
Old 11-14-2021, 08:02 PM
-NOS 6485891 Air Cleaner Assembly with double notched side construction on the snorkel and bottom flanged center groove $800 ❌ SOLD
-Used Ring Flange with "W" stamp on the back $175 ❌ SOLD
-Used Center Vacuum Pod Bracket $150 ❌ SOLD
-NOS 3968539 hood door $180
-Screens $80 each ❌ SOLD one with hole $50
-NOS A212CW Air Filter "Protect Your Engine Replace With AC Type" Diamond pattern correct assembly line $175 ❌ SOLD
-NOS 3955231 Rubber Seal $200 ❌ SOLD
-Restored 3968555 Side door bracket $60
-NOS 1998970 Vacuum pod no GM box second design $150 ❌ SOLD
-"P" bolts $15 each ❌ SOLD
-Used "COWL INDUCTION" hood emblems $15 each or any two for $25
-Used cables with full rubber coating but has patina $150 pair ❌ SOLD
-Original Cowl Induction air cleaner wing nuts black phosphate $70
-Used slide in pins need polishing $75 ❌ SOLD
-Under plastic gaskets for hood pin plates $50 pair
-Used wiring harness needs one end repaired $75
-Used DR 1114427 Assembly Line solenoids with rear "X" molding and solid spade with stamped metal part number $200 each and second design "T" rear molding $50 each. (They have all been tested and work)
-Monsanto Plastic inner flapper $60
-Inner flapper frames all restored $90 each
-Used 454 Turbo Jet 450 HP Black Air Cleaner Lid is a Reproduction top $40
Shipping Extra, Prices USD Paypal "Friends"
Old 11-14-2021, 08:03 PM
Monsanto Flapper and frames that are still in Stock
Old 12-27-2021, 03:17 PM
Picked up a second NOS 3955231 Rubber Seal $200 with FREE Shipping. (This one has a few GM Stickers)
Old 02-05-2022, 01:34 PM
10% off on all posted prices below.
