Old 12-27-2021, 03:16 PM
STEFS STEFS is offline
Yenko Premier Member
Default Single pin or Dual pin Calipers
On the 1968 Camaros with the J-56 opition were the calipers Dual pin or Single pin from the factory?????
Attachments - The Supercar Registry CDCB425A-E47E-43FA-A521-493CBAA5FF96.jpg 213A0961-6D45-4494-A120-7D67394ADA69.jpg
Old 12-27-2021, 05:49 PM
Four piston Caliper with single pin retention.
Old 12-27-2021, 06:08 PM
67 Nova Boy's Avatar
X2
Dave
67 Nova Boy
Old 12-27-2021, 08:15 PM
IIRC, Corvette was the only GM car I can remember that had dual pin pad retaining calipers and that was on the J-56 Heavy Duty brake system required on the L-88's and ZL-1's
Bill
The Following User Says Thank You to Big Block Bill For This Useful Post:
L79Chevelle (12-28-2021)
Old 12-27-2021, 08:35 PM
Bill
----Huge cotter pins to be exact.....Bill S
Old 12-27-2021, 11:01 PM
Yes, I do remember that Bill, and also a story about a guy taking his calipers in to be rebuilt on a a Corvette he bought and they had dual cotter pins. The shop he took them to said to drop the fuel tank and see if it said L-88 on the tank sticker, and Walla! Another L-88 Found!
Them were the days.
Bill
Old 12-27-2021, 11:43 PM
Thank you gentleman !!!!!!!!!!!!!
Old 12-28-2021, 02:21 AM
TimG TimG is offline
And folded over brake pad tops so the pads would not warp when hot.
Old 12-28-2021, 05:10 AM
Kurt S Kurt S is offline
There was no J56 option for 68 Camaros, just J52 power discs.
http://www.camaros.org/suspen.shtml#Brakes
Kurt S - CRG
The Following User Says Thank You to Kurt S For This Useful Post:
PeteLeathersac (12-28-2021)
Old 12-28-2021, 07:42 PM
juliosz's Avatar
juliosz juliosz is offline
My 67 Z came with J56. The original owner modified the calipers per the factory drawing to the dual cotter pin design.
The Following 3 Users Say Thank You to juliosz For This Useful Post:
69M22Z (12-28-2021), olredalert (12-28-2021), PeteLeathersac (12-28-2021)
