Old 04-04-2022, 05:38 PM
rm70z rm70z is offline
Default 186 Heads date code
Looked at a 1970z28 for a friend with 186 heads dated M 12 2 and M 12 1 , car is all original ,owner history from new , They all say never replaced , cant make sense of the
M date for month , car is late April built , any thoughts , thanks
Attachments - The Supercar Registry 5ECAF9C7-EAD7-483F-ACA4-B7F16FDC6488.jpg
Old 04-04-2022, 07:11 PM
William William is offline
http://www.camaros.org/drivetrain.shtml#BlockCast
'M' was not a date code. It was a casting code that indicated the part was made to evaluate a casting process change.
Old 04-04-2022, 07:45 PM
Steve Shauger's Avatar
Administrator
Thanks Bill & Kurt, I was looking for a thread I started in 2004 which John Z. confirmed what is stated on the CRG:
"M"-Coded Blocks
There is one exception to this convention that has been observed: some blocks have been seen with "M" cast codes. Research by the Saginaw Metal Casting Operations of GM Powertrain Division has found that these "M" codes are not date codes, but actually a foundry code used to indentify parts that were made to evaluate a casting process change. After evaluating the parts, the blocks would either be destroyed or released into production. There is no way to determine the date an "M"-coded block was poured.
www.yenko.net
www.vintagecertification.com
