Old 05-22-2022, 04:19 PM
Jeff H Jeff H is offline
Default swapping Camaro driver's door mirror glass
Has anyone tried swapping their original dated mirror glass into another mirror or NOS one (this is in reference to the 3914753 mirror)? My 69 Camaro mirror is dated 4 DMI 9 so I'm pretty sure it's the original mirror, but the chrome/metal is pitted a bit and doesn't look salvageable. I'm reading the NOS mirrors have later dates which makes sense.
Attachments - The Supercar Registry Mirror Driver orig 16.jpg Mirror Driver orig 11.jpg
Old 05-22-2022, 09:43 PM
Danzo Danzo is offline
Jeff, I have done it by holding the mirror in a vise so the glass is facing up. Fill up the mirror head with lacquer thinner and let it sit for a day (the thinner should loosen up the adhesive). Gently pry the glass loose (I have also assisted this process using a heat gun on the backside of the mirror). You can also buy dated glass for the mirror from Paragon.
Doc.
The Following User Says Thank You to Danzo For This Useful Post:
PeteLeathersac (05-24-2022)
Old 05-22-2022, 10:22 PM
169indy's Avatar
169indy 169indy is offline
Photos of similar "soak" & remove
69 Los Z11
68 SS/RS 396/325
68 Los Z28
The Following User Says Thank You to 169indy For This Useful Post:
Old 05-23-2022, 01:57 PM
Great info.
Old 05-24-2022, 01:33 AM
Thanks for the feedback.
Old 05-24-2022, 05:17 PM
Billohio Billohio is offline
I did this and chipped my glass so let it soak good and be gentle. My adhesive was tough
Bill
