Old 10-02-2022, 10:12 AM
69VN's Avatar
69VN 69VN is offline
Question D90 Stripe 1969 Camaro
I have kind of an odd ball question that I've been curious about for years. When
the designers at Chevrolet decided it was a good idea to just paint the fenders and
then follow up with putting a decal on the doors... why not just paint the rest of the
stripe on the doors??? Anyone know why it was never done this way?
Thanks,
Sal
I currently own a 1969 Camaro SS350. Although the original drivetrain is long gone, this 4/speed car has a March '69 HC coded block with #041 heads. The transmission is an M20 Muncie #660 case and the rearend is a BS coded 12 bolt posi. Built in Van Nuys.
Old 10-02-2022, 10:54 AM
IMHO . . . it was done that way to save time on the production line.
Old 10-02-2022, 11:35 AM
R68GTO R68GTO is offline
Save time and guarantee alignment of the stripe since it was applied in two different areas. I say guarantee as long as the person applying the decal did a good job
Old 10-02-2022, 12:51 PM
William William is offline
Any spray-painted striping that was applied after front sheet metal installation had to be performed in the in-line repair booth. Z10s, Z11s and Z/28s were processed that way and had to be released to final assembly so as not to over-schedule the booth. Almost 25% of '69 Camaro production received the D90 striping, adding significant burden to the area. Much faster and cheaper to apply a decal.
BTW, the DX1 stripe was finished in the same fashion-hood portion was the same decal used for D90.
http://www.camaros.org/assemblyprocess.shtml
The Following 4 Users Say Thank You to William For This Useful Post:
L78M22Rag (10-02-2022), L_e_e (10-02-2022), olredalert (10-02-2022), Xplantdad (10-02-2022)
