8 inch Balancer 3870325
What is this 0325 for exactly? Lotsa differing info on the above, e.g. COPO / Spec Hi Perf. / 1965 - 68 Chev / 1965 - 1969 Vette ?? Anyone have a pic. of the specific 8" timing cover for the above dampener?
Thanks in advance! I appreciate it! Ted |
Re: 8 inch Balancer 3870325
To the best of my knowledge, that is just the casting number of the center section of the harmonic balancer.
Phil Woj. |
I agree with Phil. The casting number is the inner section of the Balancer and was used for many applications. The weight of the outer ring is what varies the balancer from ones with the same casting.
Brandon
68 Camaro 302 Z/28 Rally Sport 68 Camaro Convertible w/427 68 Camaro Drag Car 67 Camaro Royal Plum RS/SS 67 Camaro Convertible 327 RS 92 Corvette Convertible Quasar Blue white top http://www.ebay.com/sch/usa-1musclec...pg=&_from= |
There are numbers / codes punched on the front outer ring of the balancer: 9 623 and also G2F .
They must mean something, but, what .. ?? What I am trying to establish is, good numbers for COPO L79 ??? Thanks gentlemen! Ted |
The L79 327 uses the Corvette style with the fins inside the hub.
"Knowledge is good" Emil Fabor 67 L/78 Camaro SS/RS H-H,1W,2LGSR,3SL,4K,5BY. (Sold) 70 L/78 Nova M-21,Black Cherry,Sandalwood Int. 09 Pontiac G8 GT Premium,Sport,Roof. Liquid Red. |
I believe the balancer you are asking about is for a big block Chevy 396 and 427, not a small block Chevy.
Jason |
Sorry, my bad, typo error. Should've typed L78. Trying to establish exactly what engine this came from.
Anything on the codes make sense? T. |
I have a NOS L78 shortblock, tomorrow I will check the balancer markings.
1968 Nova SS 1970 Camaro Z28 1987 Buick GN 1975 Trans Am 1972 Blazer 1968 Ford Ranger 1964 Ford short step 1929 Ford Coupe 1931 Ford Coupe 1986 GMC Wrangler 4X4 |
I'd sure appreciate that. Could you also take notice of anything specific to your timing cover also?
I believe I have the cover that came with the balancer. Just not sure if L78 COPO etc etc. or a common setup? Merci Mr Furback! Ted |
I believe the timing cover for the 69 L78/L72 is unique to that year only. I can't remember what's unique, but I think it has to do with the timing tab, and maybe the locator pins.
The Following User Says Thank You to Unreal For This Useful Post: | ||
orbit orange70 (01-30-2021) |
