Old 03-08-2018, 08:48 PM
MN 70L78 MN 70L78 is offline
Yeah I've never seen a factory POP like that but if it's a replacement then that would explain why it looks so odd.
I'm confident about the build sheet being real. If the VIN on the BS matches you're car then you should be good. Not sure how well you know 70 Z28's, make sure all the little telltale signs for being a real Z28 are present.
Scott Kiehne
70 SS L78 Camaro, born with drivetrain, 4:10's & M22, Classic Copper, Concours Restored.
70 SS L78 Camaro, Antique White w/Bright blue interior, 4:10's & M21.
Old 03-08-2018, 10:39 PM
Blown32's Avatar
Blown32 Blown32 is offline
I was a little worried about Dean's car, it's been for sale for years. It started off at 40,000, looks like it had multiple paint touch up's along with the engine modifications. I was also concerned about the missing build sheet information, most of the paper work looks correct though. All and all looks like a nice Z! Hope everything works for you if you make the deal
Old 03-08-2018, 10:57 PM
ronzz572 ronzz572 is offline
I agree with Scott. Everything looks legitimate. Build sheet looks authentic. POP. Appears to be a replacement as discussed already. Look the car over real well for any questionable features.
1970 z28 4speed cranberry red white stripes standard saddle interior.
Old 03-09-2018, 01:01 AM
Gold70Camaro Gold70Camaro is offline
Blown32_ Do you know the car or Dean?
Is there concerns about Dean or the car i should watch out for?
Old 03-09-2018, 03:15 AM
fsc66 fsc66 is offline
Default Other options
Sometimes it helps to try to disprove things that are more evident.
POP: VIN number matches production information for a Van Nuys car built in February as does the build sheet.
House address is legit and the house was built in 1950, so that's good. Now a very good sign is that the owner of the property is a R Collins and a D Collins.
https://www.spokeo.com/NM/Roswell/1806-W-3rd-St
I'd say that's a pretty darn good sign that POP is legit.
Here's the phone numbers
Phone numbers
(575) 623-1616
Landline
(575) 434-1890
Landline
I would call them and see if they can verify any info for you.
Good luck,
Paul Winvoices
[email protected]
Old 03-09-2018, 11:40 AM
FSC66
Thanks for the additonal contact info
Old 03-09-2018, 11:41 AM
Blown32's Avatar
Replied
Old 03-09-2018, 11:45 AM
TAR6569 TAR6569 is offline
That's a 2nd owner protectoplate. They didn't stamp those with drivetrain into. The 2 under the bowtie means it was the 2nd owner on the plate.
5-50 is the warranty coverage, 217 is the mileage. May be 21,700. Can't recall exactly. 03-0 means the car was originally placed in service March of 1970.
381 and counting in the 67-69 Impala SS427 registry
Old 03-09-2018, 12:16 PM
Thanks again for all the information.
It is amazing all the knowledge everyone has to share.
I am feeling better about the car and my purchase and will be glad when it arrives later next week
I did notice on the build sheet it said custom order. could have someone special ordered it then canceled causing a new protecto plate?
Old 03-09-2018, 02:52 PM
x77-69z28's Avatar
This looks just like the P-O-P from my 70Z. It had the short block replaced shortly after delivery. It is still in the original owners name. I found remnants of the original P-O-P under the carpet when I started the restoration.
Buddy
Mine is also stamped replacement on the front.
