Old 04-04-2021, 01:17 AM
KenMaisano's Avatar
KenMaisano KenMaisano is offline
There is a sliding valve in the h/l switch that moves between the vacuum ports. Sounds like the tab broke off.
If you know someone with skinny arms, they can swap the switch without dismantling anything.
Yep, That's the problem.. If i purchase a aftermarket switch can i use the metal tab out of it and install it in my original 177 switch?
https://www.yenko.net/forum/attachme...1&d=1617499042
Old 04-07-2021, 05:21 PM
William William is offline
There were other GM cars that used a vacuum h/l switch. '69 Caprice?
Even a used switch may be ok for parts.
Old 04-07-2021, 07:58 PM
68-81 Corvette -
68-69 GTO with hideaways.
William (04-07-2021)
  #14
Old 04-09-2021, 04:32 PM
KenMaisano's Avatar
Thanks for all the help guys. I silver soldered a new metal tab. It works great now.
The Following 3 Users Say Thank You to KenMaisano For This Useful Post:
napa68 (04-09-2021), NorCam (04-09-2021), Xplantdad (04-09-2021)
