Old 12-11-2023, 05:13 AM
69L78's Avatar
69L78 69L78 is offline
Default Can this 302 block be repaired?
I am looking at buying a 68 Z and the original block that comes with the car is cracked, I was told years ago it could not be repaired, but now with today's technology it could be. If it can be repaired, what would be the cost?
Old 12-11-2023, 05:22 AM
Sleeve and a helicoil/thread insert should take care of it.
Jason
Old 12-11-2023, 11:43 AM
Yes, it can be repaired. A sleeve will take care of the cylinder. Cast iron crack repair plugs should take care of the deck. A Jergens thread insert will fix the hole. Talk to a good machine shop and get their opinion because they will be the ones to do the work.
Indy Cylinder Heads had an oven that they used to weld cylinder heads. I don't know if they can do blocks too, but you might ask.
Old 12-11-2023, 12:02 PM
69L78's Avatar
Thanks for all the responses. I am in PA so I have a few choice machine shops to consider. When the engine failed years ago, it ruined the cylinder head so I am looking for a single 291 head dated no later that June 12, 1968
Old 12-17-2023, 12:47 AM
69 Post Sedan's Avatar
They do it all the time t our local machine shop…..they can “pin it” without any issues. It may have to be sleeved as others have mentioned.
Kurt
1968 Schwinn Orange Krate Original Paint
1970 Schwinn 3-Speed Deluxe Original Paint
Old 03-06-2024, 06:28 AM
Tuna Joe Tuna Joe is offline
The go to guys for cast iron repair is Lock and Stitch located in Turlock CA
I’m having a block repaired there currently. I’ll let you know how it comes out.
Not cheap!
http://www.locknstitch.com/index.html
The Following User Says Thank You to Tuna Joe For This Useful Post:
69M22Z (03-06-2024)
