Old 09-12-2017, 03:54 PM
YENKO DEUCE REGISTRY's Avatar
Default Holley 4555 Secondaries
I fired up my Yenko this past weekend, but fuel is literally pouring into the secondaries, it will barely stay running. I pulled the carb, removed the fuel bowl and looks the matter!! Any insights as to what would cause such a fuel dump?!
Marlin
Old 09-12-2017, 04:05 PM
earntaz earntaz is offline
Too much fuel pressure, crap in the needle/seat, float (if plastic) too heavy (absorded fuel). Just a few things to check ... Craig
Old 09-12-2017, 04:26 PM
As earntaz said, needle/seat or float issue most likely. Also make sure the secondary air bleeds are clean, modern gas gets gummy fast on cars that don't get driven frequently.
Old 09-12-2017, 04:32 PM
L78steve L78steve is offline
Especially if you don't use the secondary's much.
Old 09-12-2017, 05:52 PM
Ok, I'll just replace everything, I don't wanna mess around - plus it's a good tutorial for Benjamin to see how a Holley comes apart, and hopefully goes back together!
Marlin
Old 09-12-2017, 07:13 PM
jdv69z's Avatar
jdv69z jdv69z is offline
Has it been a while since it has been run? Sounds like stuck float to me. I've had this happen a couple of times. Fix might be as simple as opening float sight plug, and moving float up and down with a screw driver to free it up.
Old 09-12-2017, 09:14 PM
Marlin -- let us know what you find ... Craig
Old 09-13-2017, 09:49 PM
VintageMusclecar's Avatar
Needle & seat is probably stuck.
Read this
The Following User Says Thank You to VintageMusclecar For This Useful Post:
John Brown (09-14-2017)
Old 09-14-2017, 12:36 PM
John Brown's Avatar
Should be required reading for anyone that has a Holley carburetor.
John Brown
