Old 02-09-2020, 04:45 PM
GRAFFZ GRAFFZ is offline
Default Camaro Corvette Chevelle Nova NOS GM Mechanical Parts.
NOS GM ignition wire holder. Fits Z/28 as well as Big Blocks. It has the correct "AR"
stamped on the side.
1969-1970 Camaro Z/28 (302 + 350).
1969-1970 Camaro 396, 427, + 454 (With factory A/C) (Except Special High Performance).
***************SOLD**************
(12)NOS GM negative battery cable bolts. These negative bolts have the smaller 5/16" diameter
thread bolt with 7/16" hex head. GM used this smaller thread bolt for the negative cable on
the 1969-1970 side post batteries. The negative bolt will only work with a original GM battery
because the later batteries use larger 3/8 thread.
1969-1970 Camaro.
1969-1970 Corvette.
1970 Chevelle, Malibu, El Camino.
1970 ChevyII Nova.
1970 Pontiac G.T.O., LeMans, + Tempest.
1969-1970 Pontiac Firebird.
NOS GM brake booster check valve. Comes with rubber grommet as well.
1967-1972 Camaro, Chevelle, + Chevy II Nova.
1964-1972 Corvette.
1967-1972 Pontiac Firebird.
1964-1972 Pontiac GTO/Tempest/Lemans.
1965-1972 Oldsmobile Cutlass/F85/442.
1968-1972 Buick Skylark/Gran Sport/GSX.
NOS GM Muncie 4-Speed input shaft bearing. Goes between the input shaft and the
main shaft and fits the M-20, M-21, + M-22.
1964-1972 Camaro, Chevelle, Corvette, + ChevyII Nova.
1964-1972 Chevrolet Impala, Caprice, Biscayne, + Bel-Air (Except 1969 model year).
1964-1972 Pontiac G.T.O., LeMans, Tempest, Grand Prix, + Firebird.
1964-1972 Oldsmobile Cutlass, F-85, 442.
1968-1972 Buick Skylark, Special, + Gran Sport.
NOS GM Delco-Remy Distributor MS 201 vacuum advance. Also included is a set of
NOS Delco-Remy Heavy Duty points.
1969-1970 Camaro Z/28.
1969 Camaro, Chevelle. + Nova (396) (L34 or L35 only).
Thanks, Sam
GRAFFZ
Attachments - The Supercar Registry 9419248#1A.jpg 8900304#1A.jpg 5472419#2A.jpg 3932485#1B.jpg
Tags
1968, 1969, 1970, copo, z28
