Trying to identify this 12 bolt that was used as a roller in my 71 442. Can’t seem to find anything on the RE code. The K indicates it was made by MCKinnon in Ontario and likely for a GMCanada application. I have no need for this but did not want to junk it if there is some value to someone.
1971 W30 convert, triple green,second owner. 1971 W30 Convert, special order Rally red, under resto. 68 Charger R/T, Bullitt Replica 68 Camaro Z28,Corvette Bronze,Houndstooth www.vancouverclassiccars.com |
'71 Olds would have the Olds 8.5 10 bolt, which has a 12 bolt cover. It's not the same as the Chevy 12 bolt. A picture of the whole rear end, including the cover, would help.
Pulled a couple Chevy style 12 Bolts out of Canadian Cutlasses over the years... not sure why but they were in there. Some 69's for certain.
68 Acadian SS-350 auto/AC driver 70 Nova SS-396/375HP Bench Stick 72 Nova SS-350 5sp Mini Tubbed 67 Chevelle Conv. SS-427 clone 70 Chevelle SS-454 LS-5 M-22 |
To clarify, most were the O style but the odd one seemed to be a Chevy style
To clarify this is a chev 12 bolt that was in my car,not original to the car and not going back in. I only need to know to see if it appeals to someone looking for a 12 bolt for buildup purposes.
There is always value in an original Chev 12 bolt, even if it's only $200 as a buildable core.
The E may represent an Eaton posi. Do you know if it is a posi and what the ratio is ? I sold a core 12 bolt on here last fall and shipped it to TX via Fastenal.
The Following User Says Thank You to Too Many Projects For This Useful Post: | ||
Zman1969 (02-16-2022) |
Freddie I know inside they do look like a 8.5 but bigger! like on steroids! seems like in 70-72 there were several different rear ends each division had till they settled on the 8.5" rear in 71 and 72 like Chevelle and Pontiac were their own 8.2" and the cutlass skylarks got 8.5" Crazy!
69 RS/Z 302 VE3 Daytona 69 Chevelle SS 396 375 69 T/A clone LS6/6 speed 90 Formula 350 |
Casting date and casting number on the pumpkin?
Jeff Helms 65 Z16 Survivor 65 Z16 drag car 66 Chevelle L78 unrestored 67 Chevelle L78 unrestored 67 Camaro SS350 Survivor |
![]() Quote:
Guys
Appreciate all the info about what went into an Olds from the factory. I already know that. My question is; Does anybody know what the RE code is for on a Canadian built GM 12 bolt as described in the first post.
