Old 05-17-2022, 04:14 PM
1972convss454 1972convss454 is offline
Default 3877660 Water Neck ?
I have a question about the aluminum GM water neck part number 3877660.
I've seen two versions. One has a tab with a hole and the other version does not have the tab.
What is correct for a 1970 Chevelle L78 or LS6?
Joseph Farrow
1970 Chevelle L78
1970 Chevelle LS6
1972 Chevelle LS5
Old 05-17-2022, 06:46 PM
SS427's Avatar
SS427 SS427 is offline
What you show in the photo is correct for a 70 big block.
Rick Nelson
The Following 3 Users Say Thank You to SS427 For This Useful Post:
1972convss454 (05-17-2022), 67 Nova Boy (05-17-2022), mhm1966 (05-17-2022)
Old 05-17-2022, 08:16 PM
67 Nova Boy's Avatar
More then likely the tab broke off of the other one for a throttle return spring or some thing like that.
Dave
67 Nova boy
The Following User Says Thank You to 67 Nova Boy For This Useful Post:
Old 05-17-2022, 09:10 PM
Pacecarjeff Pacecarjeff is offline
2 versions of the 660 housing. One has numbers on the neck as shown, other is on the base. Both have the tab. If no tab, then it is a 128 housing.
The Following User Says Thank You to Pacecarjeff For This Useful Post:
Old 05-17-2022, 09:48 PM
Thanks Guys!
Joseph Farrow
1970 Chevelle L78
1970 Chevelle LS6
1972 Chevelle LS5
