Old 08-11-2022, 02:10 PM
Edgemontvillage's Avatar
Default 1969 Camaro/Firebird Deluxe Window Regulator
Looking for a passenger door, deluxe interior window regulator for a 1969 Camaro. Please PM if you can help!
Lloyd
(stock image for reference)
Old 08-11-2022, 02:35 PM
X66 714's Avatar
X66 714 X66 714 is offline
1968 deluxe is the same. It's ID is the 4 rings around the stem shaft...Joe
Edgemontvillage (08-11-2022)
Old 08-12-2022, 11:26 PM
Deluxe interior 4 ring winder stem 2" length
Standard interior 1 ring winder stem 1.5" length
The Following User Says Thank You to Edgemontvillage For This Useful Post:
X66 714 (08-13-2022)
Old 08-17-2022, 09:51 PM
LS7 LS7 is offline
Default 69 Deluxe Regulator
I believe I have a right side regulator. I've tried to PM but they are not going through. Please try to PM me, LS7. Thanks
Old 08-18-2022, 12:53 AM
Hi Dan and thanks for posting, your PMs were received. Thanks
Old 08-21-2022, 03:25 AM
ssl78 ssl78 is offline
I have one if you did not find one already
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Old 08-22-2022, 06:49 AM
I have located one that is in-bound pending receipt, will circle back if still needed - thank you for posting!
X66 714 (08-22-2022)
Old 09-02-2022, 04:20 PM
The regulator I received had a stripped crank gear so I'm still looking!
Old 09-30-2022, 05:52 PM
Located a good one! Thanks SYC and thanks John (ssl78)!
The Following 3 Users Say Thank You to Edgemontvillage For This Useful Post:
enio45 (10-01-2022), MJV1953 (10-01-2022), X66 714 (09-30-2022)
Old 10-16-2022, 04:04 AM
Your welcome
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
The Following User Says Thank You to ssl78 For This Useful Post:
Steve Shauger (10-16-2022)
