Old 12-15-2023, 08:42 PM
66cayne 66cayne is offline
Default sad, sad, sad...
I was thinking this may be a good project car until the frame pic, sad, sad, sad..
https://www.ebay.com/itm/30531480637...Bk9SR47TqfaNYw
The Following User Says Thank You to 66cayne For This Useful Post:
markinnaples (12-18-2023)
Old 12-15-2023, 09:27 PM
SS427's Avatar
SS427 SS427 is offline
That redefines the meaning of, "Needs everything". At least the seller is showing the damage.
Rick Nelson
The Following User Says Thank You to SS427 For This Useful Post:
Woj (12-19-2023)
Old 12-16-2023, 12:03 AM
I bought one worse than that about 15 years ago. Frame had sections of a donor bolted over the rust holes, as well as a donor trunk pan laid inside. Completely gutted and stripped of anything of value. When I got the bolts out of the front fenders to body the frame forward of the firewall fell on the floor. You could tell the car had been driven for some time like too.
Drove to Aline OK, bought a frame and donor body parts and built a car from there.
Carleen (12-18-2023), dustinm (12-18-2023), mhurd (12-16-2023)
Old 12-16-2023, 01:11 AM
Keith Seymore's Avatar
But - the chalk marks on the firewall survived!
We should have made the frame out of chalk.
K
'63 LeMans Convertible
'63 Grand Prix
'74 Chevelle - original owner, 9.85 @ 136 mph best
The Following 8 Users Say Thank You to Keith Seymore For This Useful Post:
427TJ (12-19-2023), 66cayne (12-16-2023), cruiserofland (12-20-2023), dustinm (12-18-2023), dykstra (12-20-2023), L72copocamaro (12-16-2023), L_e_e (12-16-2023), olredalert (12-16-2023)
Old 12-18-2023, 08:10 PM
mssl72's Avatar
mssl72 mssl72 is offline
Yes, sad to see that. I figure maybe post the VIN in case it shows up again in 1 form or another.
VIN 242177G120851
Mark
1966 L72, 4spd Caprice
1974 Z28, M40 Camaro
The Following 2 Users Say Thank You to mssl72 For This Useful Post:
Bill Pritchard (12-19-2023), olredalert (12-19-2023)
Old 12-18-2023, 08:43 PM
Pro Stock John's Avatar
Super Moderator
Bidding is up to 18K... wow.
Old 12-18-2023, 11:15 PM
well, it does have a 4 speed !
Old 12-19-2023, 02:00 PM
VIN 242177G120851
----I might be wrong but 67 Pontiacs should have star rivets! Sooo?....Bill S
mssl72 (12-19-2023)
Old 12-19-2023, 03:04 PM
Yes - rosette rivets on the VIN tag started during the '65 model year.
K
'63 Grand Prix
Old 12-19-2023, 05:07 PM
I went back to ebay and enlarged the pic there and they are definitely round head hardware store rivets. There is a shadow around the lower one from a larger rivet in the past too, which almost indicates this isn't the first time this tag has been painted over and then removed. The rosette rivet heads are rather small compared to that paint line.
