Decided to do a little updating, correcting, and cleaning up of my Chevelle this late winter/spring.
I've had this car since 1987 - my first car. I have the original born with 402/240 engine on a stand in the corner of the garage and back in 2000-ish installed a GMPP 454/425 crate motor and made it appear like the original 402 as much as I could. Things were looking a bit tired under the hood and I wanted to go through the brakes and install some of the original parts back on the car. I started disassembly back in February. Last edited by RPOLS3; 05-03-2021 at 05:47 PM. |
The Following 5 Users Say Thank You to RPOLS3 For This Useful Post: | ||
Damien (05-03-2021), dykstra (05-05-2021), kwhizz (05-25-2021), PeteLeathersac (05-03-2021), SS427 (05-03-2021) |
This whole project started out as a carb replacement. I had installed a generic speed shop Holley on the crate motor and wanted something more correct, so I called Eric and he sent me a fresh real 4492. I couldn't bolt this piece of jewelry on my existing setup without some clean up and re-freshing of the other major components.
1972convss454 (05-03-2021), big gear head (05-03-2021), dykstra (05-05-2021), kwhizz (05-04-2021), Xplantdad (05-03-2021) |
Did some paint touch up and re-plated the heater hose fittings and clamps - still the dated originals.
The Following 4 Users Say Thank You to RPOLS3 For This Useful Post: | ||
I sent out the master cylinder and calipers to NAPA to be rebuilt, had the original brake dust shields galvanized, and had a local plater re-do the gold on the caliper mounting brackets (and smog check valves). I sent the booster and master cylinder cover to Mike Gibbons. Re-detailed some of the other components I had to remove as well.
The Following 7 Users Say Thank You to RPOLS3 For This Useful Post: | ||
1972convss454 (05-03-2021), big gear head (05-03-2021), dykstra (05-05-2021), kwhizz (02-22-2022), olredalert (05-17-2021), ORIGLS6 (05-24-2021), Xplantdad (05-03-2021) |
Decided to upgrade the wheel and tire package while I was at it too. I haven't got it back on the ground yet to drive though.
The Following 8 Users Say Thank You to RPOLS3 For This Useful Post: | ||
1972convss454 (05-03-2021), dykstra (05-05-2021), GearheadSS (10-05-2021), kwhizz (05-04-2021), olredalert (05-17-2021), ORIGLS6 (05-24-2021), PeteLeathersac (05-03-2021), Xplantdad (05-03-2021) |
![]() Quote:
Based on my homework they should perform well [Uniroyal is part of Michelin]. The Eric restored 4492 is the bomb....he is the best there is. ![]() -wilma
![]() Quote:
Nice choice! I just ordered a set of American Racing wheels from 4wheelonline last week. Last edited by jandron; 05-17-2021 at 03:26 AM. |
Thank you. I was able to get these from my local speed shop guy, surprised how reasonably priced they were.
The Following User Says Thank You to RPOLS3 For This Useful Post: | ||
jandron (05-24-2021) |
Worked with Bill Hodel to get a correctly dated and restored smog pump and peripherals. More jewelry.
Sent my original alternator out to Ken Bruno and had him work his magic on it.
The Following 6 Users Say Thank You to RPOLS3 For This Useful Post: | ||
1972convss454 (05-03-2021), dykstra (05-05-2021), kwhizz (02-22-2022), olredalert (05-17-2021), ORIGLS6 (05-24-2021), Xplantdad (05-03-2021) |
Thread Tools | |
Display Modes | |
