Old 05-03-2021, 03:41 PM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
Default Chevelle updates
Decided to do a little updating, correcting, and cleaning up of my Chevelle this late winter/spring.
I've had this car since 1987 - my first car. I have the original born with 402/240 engine on a stand in the corner of the garage and back in 2000-ish installed a GMPP 454/425 crate motor and made it appear like the original 402 as much as I could.
Things were looking a bit tired under the hood and I wanted to go through the brakes and install some of the original parts back on the car.
I started disassembly back in February.
Jake Dykstra
Dykstra Motorsports
The Following 5 Users Say Thank You to RPOLS3 For This Useful Post:
Damien (05-03-2021), dykstra (05-05-2021), kwhizz (05-25-2021), PeteLeathersac (05-03-2021), SS427 (05-03-2021)
Attachments - The Supercar Registry Valve not centered.jpg Resized_20191204_183959.jpeg m_IMG_6192.jpg m_IMG_6190.jpg
Old 05-03-2021, 03:51 PM
RPOLS3's Avatar
This whole project started out as a carb replacement. I had installed a generic speed shop Holley on the crate motor and wanted something more correct, so I called Eric and he sent me a fresh real 4492. I couldn't bolt this piece of jewelry on my existing setup without some clean up and re-freshing of the other major components.
Jake Dykstra
Dykstra Motorsports
1972convss454 (05-03-2021), big gear head (05-03-2021), dykstra (05-05-2021), kwhizz (05-04-2021), Xplantdad (05-03-2021)
Old 05-03-2021, 03:54 PM
RPOLS3's Avatar
Did some paint touch up and re-plated the heater hose fittings and clamps - still the dated originals.
Jake Dykstra
Dykstra Motorsports
The Following 4 Users Say Thank You to RPOLS3 For This Useful Post:
1972convss454 (05-03-2021), dykstra (05-05-2021), ORIGLS6 (05-24-2021), Xplantdad (05-03-2021)
Old 05-03-2021, 04:00 PM
RPOLS3's Avatar
I sent out the master cylinder and calipers to NAPA to be rebuilt, had the original brake dust shields galvanized, and had a local plater re-do the gold on the caliper mounting brackets (and smog check valves). I sent the booster and master cylinder cover to Mike Gibbons. Re-detailed some of the other components I had to remove as well.
Jake Dykstra
Dykstra Motorsports
The Following 7 Users Say Thank You to RPOLS3 For This Useful Post:
1972convss454 (05-03-2021), big gear head (05-03-2021), dykstra (05-05-2021), kwhizz (02-22-2022), olredalert (05-17-2021), ORIGLS6 (05-24-2021), Xplantdad (05-03-2021)
Old 05-03-2021, 04:04 PM
RPOLS3's Avatar
Decided to upgrade the wheel and tire package while I was at it too. I haven't got it back on the ground yet to drive though.
Jake Dykstra
Dykstra Motorsports
The Following 8 Users Say Thank You to RPOLS3 For This Useful Post:
1972convss454 (05-03-2021), dykstra (05-05-2021), GearheadSS (10-05-2021), kwhizz (05-04-2021), olredalert (05-17-2021), ORIGLS6 (05-24-2021), PeteLeathersac (05-03-2021), Xplantdad (05-03-2021)
Old 05-03-2021, 04:06 PM
RPOLS3's Avatar
Worked with Bill Hodel to get a correctly dated and restored smog pump and peripherals. More jewelry.
Jake Dykstra
Dykstra Motorsports
Old 05-03-2021, 04:08 PM
RPOLS3's Avatar
Sent my original alternator out to Ken Bruno and had him work his magic on it.
Jake Dykstra
Dykstra Motorsports
The Following 6 Users Say Thank You to RPOLS3 For This Useful Post:
1972convss454 (05-03-2021), dykstra (05-05-2021), kwhizz (02-22-2022), olredalert (05-17-2021), ORIGLS6 (05-24-2021), Xplantdad (05-03-2021)
Old 05-03-2021, 04:11 PM
RPOLS3's Avatar
Still waiting on my fuel pump back from Fred Ballard so I can finish the re-assembly of the front of the engine and fire it up. Also waiting on the rear cylinders from Karp's to complete the brakes, will install a new rubber line on the rear to the distribution block as well. It's been and enjoyable project as I am not on a hard deadline and have the space - but hope to have it complete soon to be able to enjoy the summer season. Will post more as I make more progress - thanks for following along.
Jake Dykstra
Dykstra Motorsports
1972convss454 (05-03-2021), dykstra (05-05-2021), kwhizz (02-22-2022), ORIGLS6 (05-24-2021), Too Many Projects (05-05-2021), Xplantdad (05-03-2021)
Crush Crush is offline
Nice updates
Are the foam pads hanging by doors there to prevent door dings?
The Following 2 Users Say Thank You to Crush For This Useful Post:
kwhizz (02-22-2022), RPOLS3 (05-03-2021)
Old 05-03-2021, 04:13 PM
ORIGLS6 ORIGLS6 is offline
LOVE IT!!!
The Following 3 Users Say Thank You to ORIGLS6 For This Useful Post:
dykstra (05-05-2021), kwhizz (05-04-2021), RPOLS3 (05-03-2021)
