Old 07-10-2016, 02:44 AM
rcc rcc is offline
Default Rocker Arm Studs?
Is there anything our there that is really the correct 1970 LT1 rocker arm stud? By that, were all the studs for 70 Lt1's the same length or did they vary by application--i.e. Z28, Corvette or Yenko? I have found studs that are supposedly for 70 LT1's that are less than 1 and three fourths inches in length to some that are more than 2 and one half inches in length. Some are "press-in" and some are 7/16" screw in. My major concern in the "shoulder height". I need a few for my 70 Yenko.
Rick
1956 Bel Air Nomad
1961 Ford Starliner, the "Tangerine Dream"
1963 Olds Jetfire, 1 of 13 Fluid-Injected & Turbocharged
1966 Dodge Hemi Charger the "White Elephant"
1970 Dodge Challenger R/T, the "Cream Dream Shaker"
1970 Nova Yenko Deuce
Old 07-10-2016, 01:24 PM
earntaz earntaz is offline
Default Re: Rocker Arm Studs?
I may be wrong -- but I was under the impression that all LT-1s had screw in rocker studs. TAZ
Old 07-10-2016, 01:36 PM
resto4u resto4u is offline
I believe GM LT-1 studs where push in, and have heard of them failing under too much spring pressure. Go with screw in studs.
67 Z28, 67 RS/SS 396 Canadian, 73 Camaro Z28/LT Carolina Blue
Old 07-10-2016, 01:48 PM
x77-69z28's Avatar
My 04D LT-1 has screw in studs
Old 07-10-2016, 01:51 PM
ssl78 ssl78 is offline
I believe 1969 186 heads were pressed in studs and 1970 were all screw in studs
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Old 07-10-2016, 02:28 PM
rcc rcc is offline
For what it's worth, my 70 186 heads are definitely 7/16x14 screw in's. It's the overall lengths of the studs that concern me the most. Some are less than 1 3/4 inches in overall length while others are more than 2 1/2 inches in overall length. Doesn't that change the "shoulder" height or configuration?
Rick
1956 Bel Air Nomad
Old 07-10-2016, 03:53 PM
bigsixman bigsixman is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: ssl78</div><div class="ubbcode-body">I believe 1969 186 heads were pressed in studs and 1970 were all screw in studs </div></div>
This ^^^^^
69 camaro X11, 56,000 miles, original HO paint
67 camaro SS/RS, Butternut yellow, bench, fold down
Old 07-10-2016, 03:30 PM
Another thing just occurred to me -- don't confuse LT-1 studs with LT1/LT4 studs ... they are different. The early 350s where LT-1s ... TAZ
Old 07-10-2016, 04:47 PM
67 Nova Boy's Avatar
Factory studs in 1970 are 3/8-24...not 7/16-14 right? 7/16 is a upgrade from B/B.
Dave
67 Nova Boy
Old 07-10-2016, 05:11 PM
I may be wrong on this -- but the experts will chime in ... I believe the studs are 7/16 into the head and 3/8 for the rocker nuts ... TAZ
