Old 01-03-2025, 04:40 PM
chevyman0429's Avatar
Default Horns and Evaporust
I just bought a set of horns for my 69 chevelle and was told they do not work so before sending them out to be rebuilt I thought id soak in evaporust . Any chance anyone has tried this before ? My last set I got to work by spraying PB blaster in the little screw hole but they don't sound to great ! Thanks
1969 SS 396 chevelle
1978 chevy shortbed step side
1983 chevy shortbed
1985 chevy shortbed
Attachments - The Supercar Registry C7532326-81BA-4642-8CD2-7BFB983ED2B8.jpg 939BB5DC-0716-48CD-81CB-A90ADBAF0C31.jpg 6BE5A012-7CD1-4AF0-99F4-7F52F982CCF3.jpg
Old 01-03-2025, 07:59 PM
Rsconv68 Rsconv68 is offline
Default Horns
If you’re sending them to Gary, just do it. Rust is only 1 of the factors the cause the horn to fail, but not the primary IIRC. Moisture also causes corrosion on the points assembly. Considering it’s mounted on the front where it’s attacked by rain, snow, sand, and everything else, I’m surprised the last as long as they do. I’ve attached a few pictures of a horn that Gary started but didn’t finish because a found a matching date coded horn.
The Following 5 Users Say Thank You to Rsconv68 For This Useful Post:
Billohio (01-03-2025), chevyman0429 (01-03-2025), dykstra (01-05-2025), olredalert (01-03-2025), ragtop (01-04-2025)
