Old 04-14-2007, 12:18 AM
Born30YrsLate Born30YrsLate is offline
Default Getting Factory Aluminum Finish Back
If an aluminum part has been bead blasted, is there a way to get the factory aluminum color/finish back?
All input is appreciated!
I don't think it was coincidence that the Great Depression happened during Prohibition...
Old 04-14-2007, 01:58 AM
kwhizz kwhizz is offline
Default Re: Getting Factory Aluminum Finish Back
Fred........After Glass Beading........Use this.....Follow the Directions and you'll probably have to do a couple of applications to "Even" out the finish and eliminate any streaking
and then it will turn out like this
Ken
Old 04-14-2007, 02:39 AM
Carb & intake look beautiful,but damn that's some nappy looking hose.
Old 04-14-2007, 02:42 AM
TDW TDW is offline
CRACKS ME UP!!!!!!! I'm laughing my A## off!!!!
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
Old 04-14-2007, 04:13 AM
indyjps indyjps is offline
last months hot rod had a good product in it. Ill try ot find it when I get home.
Old 04-14-2007, 04:15 AM
YenkoYS-199Stinger YenkoYS-199Stinger is offline
There is that word again.
The aluminum looks great. I need to get some of that. The cleaner that is, not the nappy.
Chris
1967 Yenko Stinger YS-199
Southeast of Disorder
Chris
1966 Yenko Stinger YS-070
1969 Yenko Stinger YS-320
Old 04-14-2007, 04:42 AM
If you hit the manifold with plastic media after bead blasting it will level out the finish. Oven cleaner followed by dry fine steel wool also gives good results.
Jason
Old 04-14-2007, 04:55 AM
ORIGLS6 ORIGLS6 is offline
I'm a big fan of the Eagle 1 stuff. I used it on an old GM dual quad intake without blasting it and had almost the same results.
Old 04-14-2007, 05:09 AM
RamAirDave RamAirDave is offline
If the blasting was thoroughly done, shouldnt really need a product afterwards to even it out. I prefer a fine steel wool rub down after blasting:
Before
TheMuscleCarGuys.com
Old 04-14-2007, 06:18 AM
------You leaving those studs in there, RAD??? How thick a spacer are you using??? Hey, spacers are day 2, dont ya know!........Bill S
