Old 01-25-2018, 08:43 PM
68bronze 68bronze is offline
Banned
Send a message via AIM to 68bronze
Default 396 valve covers
i have a 396 i would like to put the stock chrome valve covers on the motor the valve train has 1.7 crane roller rockers will the felt pro 5/16 gaskets will clear or what will ? thank you
Old 01-27-2018, 06:37 AM
http://www.cfrperformance.com/CHEVY_...z-9504-t-c.htm
AFAIK the stock valve covers won't fit with 1.7 rocker arms. These look just like the stock ones but are a bit taller.
Old 01-27-2018, 02:44 PM
1971ls6's Avatar
1971ls6 1971ls6 is offline
Yes, you will need to remove the drippers if it has them
Old 01-27-2018, 04:04 PM
William William is offline
The 'recessed corner' is not correct for any passenger car.
Old 01-27-2018, 04:30 PM
Did they do that so they could be easily removed without hitting the power brake booster?
Old 01-27-2018, 05:07 PM
On Corvettes, yes.
Old 01-27-2018, 05:47 PM
1967 4K's Avatar
1967 4K 1967 4K is online now
If your putting these on a 67-68 camaro the spark plug wire loom holder is too far back on the cover to clear the windshield wiper motor. The cover being a bit taller would increase the possibility of the loom holder hitting the wiper motor.
1967 4K
Old 01-27-2018, 07:16 PM
Let me clarify this post. The original poster had received no responses to his question. I did a little research and found that 1.7 rocker arms will hit the bottom of a stock valve cover. The recommendation was to go to a taller "stock looking" cover. I did a simple GOOGLE search and came up with these. I am sure these are not the only ones available.
At least I got you guys responding
Let the original poster do his research and see what he comes up with.
Lee
Old 01-27-2018, 09:43 PM
scuncio scuncio is offline
For the record 1.7:1 is the stock BBC rocker ratio. It's the larger roller rocker body that creates the clearance issue to the drippers.
Old 01-27-2018, 09:53 PM
Banned
the valve covers i got has no drippers, i was told that if i used the fel-pro 5/16 gasket they would work
