Old 03-26-2019, 08:43 PM
302moz 302moz is offline
Default 1968 396 Block 440 casting
Wanted a 1968 casting number 3935440 4 bolt 396 block .Must not have any sleeves. Dated April ,May , June 1968. Thanks Call /text 9063371025 or 9063373928 shop
Old 03-27-2019, 01:32 PM
Default 396 Block
That date is too early. The assembly date is 0618 . End of May beginning of June date would be perfect. Thanks
Old 03-28-2019, 01:05 PM
WILMASBOYL78's Avatar
Default 440 block...
John...
I don't understand...2-3 months prior is not uncommon
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 03-28-2019, 02:35 PM
Default 440 block
Ok . The other original ones are closer . Brent’s car for example.
Old 03-28-2019, 02:36 PM
Default Engine assembly
I have the pop and the assembly date is 0618.
Old 03-28-2019, 04:40 PM
Post date code...
I understand about the assembly date...our 68 L78 motor was assembled on 6/10/68. I believe our engine block has a May date..I will have to check.
Other bolts-on will have earlier dates...especially those that were batch produced like carbs, dist, alt, water pump, etc.
The later builds do tend to have casting dates for the engine closer to the assembly date...but, it's not a cast in stone situation. The block offered with the May date would seem to be ideal...but, since it will never be the VIN motor, a few weeks shouldn't make a difference in the value or presentation.
I will get you some photos of the items we discussed this weekend.
Tom
02 Berger 380hp #95
Lots of L78 Novas
70 Orange Cooler
69 Camaro
Old 05-26-2019, 12:51 AM
Default Block
Still looking thanks
