Old 04-18-2020, 06:20 PM
Steve Shauger's Avatar
Administrator
Default Index L-M
L-M
Leaf springbushing - front #362108 - Post441
Leaf springcomparison original vs. reproduction and installed -Post 441
Leaf springhardware original -Post 402 & Post441
Leaf spring J-nutssafety issue - Post465
Leaf spring- rubber #3908370 for spring eye - Post186 & Post441
Leaf springshackle plates restored - Post442
Leaf springstampings - Post201
Licenselight fixture removed -Post 275
Licenselight fixture original restored vs. Service replacement - Post667
Mirror -rear view original and Paragon replacement -Post 214
Muncie shiftball with Knob (NOS) #3922525 – Post1138
Muncieshifter boot retainer ring screws – Post1077
Muncieshifter bracket original bolts installed – Post1408
Muncieshifter nuts with washers attach rods to transmission - Post748 & 750
Muncieshifter original Niagara orange cap -Post 378
Muncieshifter original handle re-chromed -Post 374
Muncieshifter rods BB vs. SBC - Post409
Muncieshifter with console (under cover) – Post1020
Muncieshifter with stabilizer bar (Note: there were 3 different stabilizer bars usedbetween engines and transmissions) -Post 385 & 409& 859
Moldingreveal – Post 1077
www.yenko.net
www.vintagecertification.com
67 Nova Boy (02-05-2023)
  #12
Administrator
Default Index O-Q
O-Q
Oil dipsticks ‘68Z two versions – Post1041
Oil filterPF-25 original with embossed bottom - Post328
Oil filterPF-25 and PF29 - Post666
Oil FilterPF-29 correct for 1968 - NOS vs. Repro – Post1312
Oil filterstenciling - Post677 & 680
Oil pandifferences original vs. Service replacement -Post 412
Oil panready to paint - Post472
Oil pansplash shield original round hole - Post412
Oil pressureline and fitting link to CRG – Post830
Oil pressureline fitting to block – original – Post845
Oil pressureline fitting installed - Post902
Oil pressureline routing – Post1020
Paint – 1ststep, Lonny washing to prepare for paint -Post 174
Paint – 2ndpictures of body after wet sand and buff -Post 289 & 290
Paint primersteps – Post 79,85 & 97
Paint Z/28stripes layout – Post1084 & 1087
Paint Z/28stripes original parts – Post3 & 963
Paint Z/28stripes painted on – Post1144
Parkinglight bulbs – Post1146
Parkinglight fender bezel -Post 373
Parkinglight grille original housing, lens, screws and gasket -Post 334
Parkinglight quarter panel installation and bolt up – Post1014
PCV -ventilation valve spun correct vs. Service replacement -Post 369 & Post633
Plasticscratch remover “Novus” - Post634 &639
Plugs rubberrear quarter original #4805844 -Post 419 and #4802102Post 590
Plugs rubberrear quarter original installed – Post979
Quarterwindow glass and seals original - Post596
www.yenko.net
  #13
Old 04-18-2020, 06:21 PM
Administrator
Default Index R
R
Radiator capRC-15 original vs. reproduction -Post 369
Radiator capRC-15 original 68 and 69 restored - Post508 & 1098
Radiatorclutch fan stamped 11 2 67 SC -Post 258
Radiatorpetcock original ‘Weatherhead Company’ -Post 298 &1094
Radiator tagoriginal - Post202 & 1094
Radiospeaker AM front original -Post 578
Rag joint -‘68 original on left ‘67 Corvette right one - Post140
Rag jointrestored - Post163
Rally wheelDF showing two kinds font - Post430 & Post607
Rally wheelpaint #1403 Krylon dull aluminum to argent silver - Post 520
Rally wheelwith tire micro weights - Post285 & Post335
Rally wheelwith trim ring and centers (NOS) 1980 – Post1173
Rally wheelvalve stems - Post 566& Post 575
Rear 12 boltair vent - original vs. reproduction (nice) – Post819
Rear 12 boltbumper rubber and hardware installed -Post 442
Rear 12 boltstamping BV 1129 G1 - Post169
Rear 12 boldhardware - #3930052 cushion and installation -Post 445
Rear 12 boltring gear dated 11/67 and axles – Post116
Rear 12 boltU-bolts - Post 429& Post 441
Rear 12 boltyoke - Post 369,with like new slinger - Post 377
Rear glassinterior trim painted – Post979
Roger Deanemblem – Post 848
Rocker panelmolding (NOS) – Post 78
Rust PreventionMagic - Post 375
www.yenko.net
  #14
Old 04-18-2020, 06:22 PM
Administrator
Default Index S
S
Seal#3921853 and clip (LH) below master cylinder – original – Post957
Seal#3921853 and clip (LH) below master cylinder installed – Post963
Seal seamer- cowl - Post140
Shockabsorber rear and cap – Original – Post979
Shockabsorber rear installed picture – Post1409
Smog pumpset-up (not used) - Post319
Spark plugwire loom - left side - Post373 & 979
Spark plugsAC43 comparison - Post300
Speedometercable CA and FB plug original -Post 510
Speedometercable clips original - Post511, 523 &1408
Spoilerfront – Post1158, 1170& 1252
Spoilerfront screw location with dimensions to AIM for reference – Post1252
Spoilerfront screws – phosphate – Post1301
Spoiler rearinstalled with acorn nuts –Post1170
Spoiler rearacorn nuts original 7/16 inch height – Post1330
Stabilizerlink hardware differences - Post195
Stampingsbody panel parts -Post 138
Starterbrace original vs. Service replacement -Post 565
Starterpainting per John Pirkle Jr. and NCRS link -Post 627
Startersolenoid cap brown vs. black -Post 630
Steeringarms and knuckles #3902519 and #3902520 original markings -Post 155 &Post 156
Steering boxnut and washer – phosphate – Post1302 & 1407
Steering boxoriginal with RSC cover bolts -Post 253
Steering boxoriginal with date code 3567 (12/22/67) -Post 594
Steeringknuckles restored with paint markings -Post 262
Steering ragjoint installed - Post800
Steering tierods – Post 1176
Steering wheeloriginal – Post 936& 937
Subframe – Post 105 & 107
Subframeassembly - Post287
Subframebody mount - #3901361, #3928380 and #1408366 – Post158
Subframebody mount washer #3901365 -Post 365
Subframebolts originals restored -Post 252
Subframebolt and washers as installed - Post795 & 1409
Subframemount #3 taping - Post262 &1301
Subframemounts to body and install -Post 752
Subframepainted - Post 138& Post 140
Sunvisorbrackets original re-chromed -Post 374
Suspension andsteering component finished pictures – Post1407 & 1408
www.yenko.net
  #15
Old 04-18-2020, 06:23 PM
Administrator
Default Index T
T
TachometerTic-Toc-Tach original - Post279 & Post335
Taillightbezel gaskets - original -Post 275
Taillightbezel installed – Post1014
Taillightbezels re-chromed - Post374
Taillightbezels restored - Post513
Taillightbulb connectors original -Post 310
Taillightlens wick, seals and screws #5959164 – Post980
Temperaturesending units (three types) – Post1098
Temperaturesending units (original type) and connector – Post1111
Timing gearcover original bolts -Post 201
Tire -Goodyear Wide Tread January ‘68 dated -Post 535
Tirepressure sticker - original on glove box door – Post52 & 905
Tire jackshaft re-plated - Post249
Tire valvestem length and “Schrader” cap -Post 535
Transmissionbell housing original (Note paint & yellow crayon mark) – Post36
Transmissioncross-member Muncie shifter - Post302 & &361
Transmissiondrain plug “W”- Post 45
Transmissionrebuild – Post 126
Transmissionreverse back--up light switch cover plate - original with stamping – Post902
Transmissionreverse back-up light switch holder #3864296 original -Post 397
Transmissionreverse back-up light wiring to cowl connector - Post726
Transmissionshift levers and AIM back-up switch -Post 714
Transmissionstamping P8T29 December 29, 1967 – Post45 & 231
Trim - wheelwell and rocker spears (#3904540) installed – Post1151
Trunk bumperjack shaft re-plated – Post249 & 1187
Trunk bumperjack UN hook – Post1187
Trunk gastank neck cover - original -Post 251
Trunk lidPosi glued and jacking instructions on – Post1161
Trunk lid -removal of washer marks -Post 350
Trunk lidrubber bumper #4721222 – Post86
Trunk lockretainer and screw – Post1048, 1053& 1065
Trunk shockcap original vs. reproduction - Post423
Trunk spare tireholder and original wing nut vs. reproduction – Post1187
Trunkspatter 1st attempt (wrong) - Post243
Trunkspatter 2nd attempt (correct) – Post964
Trunkweatherstripping - original type with string and later NOS – Post1098
Trunk wiringharness clip installed – Post1068
www.yenko.net
  #16
Old 04-18-2020, 06:24 PM
Administrator
Default Index U-W
U-W
U-Jointsoriginals – Post 861
Uppercontrol arm washer - original to reproduction -Post 241
Valve covergrommet #14091870 -Post 626
Valve covers(NOS) purchased 1979 - Post483
Vin hiddencowl – painted - Post10 & 150
Voltageregulator restored dated 7M -Post 148
Water pumpby-pass hose being painted - Post941 & 964
Water pumporiginal hose fittings re-plated -Post 249
Water pumpZinc fittings ground strap with heater hose elbow - Post1309
Wheel housepreparation – Post 106
Wheel stud -original - Post182
Window stickerreproduction – Post1261 & 1265
Windshieldwasher bottle cap and hose original – Post327 & 1119
Windshieldwasher pump original #4912365 vs. later #4919332 - Post225
Windshieldwasher pump restored - Post270
Wiper arm bladescorrect -https://www.camaros.net/forums/2822410-post886.html]Post 886[/url],895, 898& 899
Wiper armmechanism before after Evaporust -Post 258
Wiper motororiginal dated 35167 - Post520
Wiper motororiginal #5045441 and how to test – Post900
Wiper motororiginal #5045441 and stenciled date code – Post902
Wiringharness - engine connector (has wrong yellow zinc bolt) -Post 809
Wiringharness - engine connector with correct clear zinc bolt – Post820
Wiringharness engine - original alternator boot, push in pins black - Post 344
Wiringharness - engine - original push in plugs black – Post1119
Wiringharness junction block - original restored -Post 366
Wiringharness - trunk original vs. reproduction -Post 311
Wiring harness - trunk installation of clips – Post1014
Wiringharness - trunk ground screw Zinc – Post1014
Wiringharness - trunk ready for installation -Post 501
www.yenko.net
The Following 5 Users Say Thank You to Steve Shauger For This Useful Post:
67 Nova Boy (02-05-2023), 68camaroz28 (04-18-2020), Billohio (04-18-2020), COPO (04-18-2020), enio45 (04-29-2020)
  #17
Old 04-18-2020, 07:11 PM
bergy's Avatar
bergy bergy is offline
This should definitely be a published book!
  #18
Old 04-18-2020, 07:29 PM
Administrator
I agree Bruce, and a huge thank you for contacting me to initiate this thread!
www.yenko.net
Old 04-18-2020, 07:40 PM
Thanks to Bruce for relaying on to Steve and special thanks to Steve for the kind words and placement on this great website. Also as you mentioned Steve in the beginning my friend Bob (aka camarocards) was instrumental after I completed the table of contents adding all those links. It became a real team effort!
Thank again,
Chick
68,69&2015 Z/28's
Few Corvettes
The Following 3 Users Say Thank You to 68camaroz28 For This Useful Post:
camarocards (04-19-2020), enio45 (04-29-2020), luv2sixty9 (04-18-2020)
  #20
Old 04-18-2020, 08:58 PM
You really should look into publishing it as a book.
