Chick (68 Camaro Z28) with the assistance of Bob Cardillo produced the most detailed and comprehensive restoration document I've ever seen. This is a step by step picture documented restoration, which solves myths, and leave no stone unturned. A big thank you for providing this, and sharing with our members! The stunning finished product... Index is located in the following post.
Steve Shauger The Supercar Registry www.yenko.net Vintage Certification™ , Providing Recognition to Unrestored Muscle Cars. Website: www.vintagecertification.com Last edited by Steve Shauger; 04-18-2020 at 06:27 PM. |
The Following 13 Users Say Thank You to Steve Shauger For This Useful Post: | ||
67 Nova Boy (04-18-2020), 68camaroz28 (05-01-2020), bergy (04-18-2020), BillD (03-20-2023), camarocards (04-18-2020), dykstra (07-12-2021), HawkX66 (04-18-2020), L78 Fred (03-21-2021), mhm1966 (11-08-2021), napa68 (11-27-2022), SS427 (04-19-2020), X66 714 (02-05-2023), ZLP955 (04-19-2020) |
Alphabetical Index A
Chick’sTeam Camaro Build Thread - Time for Another 68 Z/28 to be Restored Tableof Contents 68Z-1970 Pictureof Eddie Meadows (orig. owner) – Post32 68Z-1983Purchase - what I brought home in pieces - Post1244 68Z-2010 Howit looked from lacquer paint job in mid-80’s - Post1 68Z-2016 Sawsome sunlight for 1st time since 1979 – Post1263 68Z-2017 Reunitedwith original owner Eddie Meadows – Post1317 68Z-2017 Picturetaking for Hemmings Muscle Machines – Post1348 A-Armassembly painted - Post272 A-Arm rubberflap shields-drilling NOS inner fenders – Post1045 A-Arm rubberflap shields making staples – Post1045 A-Arm rubbermaterial with cords – Post971 A-Arm shims- Post 674 A-Arm upperrubber bumper #384220 -Post 214 Air cleanerconnector #3923260 to valve cover -Post 592 Air cowlplenum air filter A226CW original vs. later -Post 236 &241 Air cowlplenum air filter cheap replacement – Post1191 Air cowl plenumcarb stud – Post 1013 Air cowl plenuminstalled – Post 1191 Air cowl plenumoriginal installation – Post1011 Air cowl plenumoriginal seal – Post1013 Alternator -after restoration original dated 7H10 -Post 148 Alternator -before restoration original dated 7H10 – Post46 Alternatorbrackets - comparing original GT stamp to reproduction stamp -Post 160 Alternatorbracket to header and alternator installation - Post795 Alternatorbracket alignment front vs. rear on alternator -Post 800 Alternatorbracket alignment rear of alternator vintage picture -Post 804 & 806 Alternatorwiring boot original - Post344 Aluminumrestoration, intake and distributor – Post128 Assembly ofcar - rear in subframe in front -Post 454 Assembly ofcowl (Firewall) and under dash list – Post839 Assembly offenders and front end - 1069& 1073 Astroventilation parts and info -764
Steve Shauger The Supercar Registry www.yenko.net Vintage Certification™ , Providing Recognition to Unrestored Muscle Cars. Website: www.vintagecertification.com Last edited by Steve Shauger; 04-18-2020 at 06:29 PM. |
The Following User Says Thank You to Steve Shauger For This Useful Post: | ||
67 Nova Boy (02-05-2023) |
Yay!
B
Ball jointsriveted - Post160 Batterycable negative clips #3857706 -Post 609 & 612 Batterycable negative clips #3857706 located on frame -Post 621 Batterycable negative clips - how to install -Post 682 & 687 Batteryground for Y55 - location and hardware – Post1191 Battery holddown clamp bolt - original with 0.87 inch diameter washer - Post1293 Battery holddown clamp NOS correct piece – Post860 Battery holddown clamp original vs. Service replacement-Post 366 & Post490 Battery holddown clamp original dip painted and stampings – Post1293 Battery holddown clamp painted original survivors (3) - Post511 Battery holddown clamp restored and bolt – Post1183 Battery tray– Post 1273, 1275,1276, 1280,1281, 1283& 1287 Battery traycontinued – Post 1291& 1292 Battery traycontinued - how to make tab correct - Post1304 Battery Y55NOS purchased 1983 (no Energizer script) – Post1183 Battery Y55NOS early 70’s vintage with Energizer script- Post1261 Battery Y55 -How to gut – Post1394 & 1396 Bezels - Sidemarker lights painting grooves black – Post959 Body and componentsmedia blasted to bare metal – Post8, 9 &10 Body rubberflap in rear quarter housings - originals -Post 196 Body work –Post 53, 59,61, 65,69 & 98 Body workcontinued – Post 106& 113 Brakebooster hose bracket-original vs. reproduction -Post 269 Brakebooster restored and hardware - Post155 Brakebooster valve comparisons original to later types – Post814 Brake boostervalve comparisons original to newer reproduction found – Post1306 & 1309 Brakebooster valve and seal #546180 both original -Post 607 Brakebooster valve and seal with original clamp installed – Post902 Brake clutchpedal assembly restoration -Post 410 Brake druminternal components and stamping -Post 258 Brake drumpaint for components - close match -Post 262 Brake drumshoes and assembly -Post 486 Brakeemergency cables with hardware installed – Post1409 Brake hoserubber U-shaped clips - original to reproduction -Post 182 & Post259 Brake hoserear original - Post280 & 302 Brake lineand hardware installed pictures – Post1176 Brake lineclips and hardware (note - ignore bluing for ’68) -Post 524 Brake lineclips and hardware by part number in AIM -Post 541, 543& 545 Brake lineclips and hardware by part number in AIM -Post 587 Brake linerear bracket original vs. reproduction - Post416 Brake linerear bracket with bolt attached to 12 bolt - Post448 Brake mastercylinder (found out later a re-stamp) – Post129 & 796 Brake mastercylinder and booster NOS 5/31/68 – Post851 Brake mastercylinder WT original vs. re-stamp – Post1362 Brake mastercylinder WT original rebuilt and valve with distribution block – Post1365 Brake systemdirectional block and valve restoration – Post852 Brake systemvalve nut re-face (Note valve nut should be phosphate for ‘68, clear zinc for’69) – Post 856 Bucket seatrail for seat in and out - Post304 Bumper frontinstallation – Post1161 Bumperguards NOS – Post 114 Bumper rearNOS guards and installation – Post1151 Bumper rearlicense plate light Bracket installation and light differences – Post1146
Steve Shauger The Supercar Registry www.yenko.net Vintage Certification™ , Providing Recognition to Unrestored Muscle Cars. Website: www.vintagecertification.com Last edited by Steve Shauger; 04-18-2020 at 06:26 PM. |
C
Car Show:11/2016 MCACN - Celebrity Pick Award winner – Post1267 Car Show:12/2016 East Coast Indoor Nationals December 2016 - Two awards – Post1272 Car Show:06/2017 Camaro Nationals, Gold – Post1317 Car Show:06/2017 Camaro Nationals judging demerits – Post1329 & 1330 Car Show:06/2017 Camaro Nationals judging demerits – Post1349 Car Show:06/2017 Camaro Nationals judging demerits – Post1355 & 1360 Car Show:11/2018 MCACN 999/1000 and Platinum Pick best stock Chevrolet – Post1382 Car Show:06/2019 AACA Senior award – Post1398 Carb dated7A1 List 4053 – Post 68 Carbmanifold stud – Post1087, Post 1111& 1119 Carbmanifold stud information (Stan NCRS judge) – Post1189 Carb studoriginal ‘68Z - Post592 & 1011 Car cover(have 4 of these) no longer available – Post1157 Chromedoriginal items - Post757 Clutchbellcrank lower push rod -Post 791 Clutch fork#3892632 and spring - Post590 Clutch forkhardware and GM number list -Post 683 Clutch forkspring and rod attachment issue with headers – Post823 Clutch forkspring and rod attachment issue with headers fixed – Post960 Coil springtag Skip’s ‘68Z survivor -Post 540 Consolegages original - Post279 Consolerestoration pictures + (part numbers) and installed – Post1138 Consolespecial nuts #3792287 -Post 691 Cowlinsulation under dash pad (NOS) - purchased 1979 - Post414 & 419 Cowlinsulation under dash pad (NOS) - purchased 1979 restored -Post 449 Cowl insulationunder dash pad rubber plugs original #3868790 -Post 595 Cowl paintedblack - before paintPost 140 & afterpaint - Post150 Cowl paintedbutternut yellow blend in -Post 243 Cowl panelseal #3927464 – Post963 Cowl panel -Z28 stripe dimensions – original - Post3 & 963 Cowl pictureshowing locations clips, lines, speedo, oil, grounds, etc. - Post 719 Cowl reversebackup light wiring to cowl connector -Post 726 Cowl seal#3927464 – Post 62 Cowlstampings PTB Post 692& 698 (green)
Steve Shauger The Supercar Registry www.yenko.net Vintage Certification™ , Providing Recognition to Unrestored Muscle Cars. Website: www.vintagecertification.com |
D
Dash heaterand defroster control panel restoration original -Post 775 Dash installed– Post 1111 Dealershipscript, Roger Dean added to car – Post 1265 Dimmerswitch grommet original -Post 745 Disc brakecaliper original 4 piston -Post 163 & paintedPost 404 Disc brakedistribution block and pressure regulation valve -Post 186 Disc brakehose bracket - Post160 Disc brakehoses (NOS) - stenciled - Post351 Disc brakemounting plate original re-plated -Post 249 Disc brakeshoe kit #5470879 - Post429 Disc brakepressure regulation valve ‘68 to ’69 – Post877 & 880 Distributorcap D308/D308R - Post594 Distributororiginal #1111266 dated 7A25 - Post52 & 664 Distributorvacuum lines - Post581 Door armrest pads, original vs. PUI – Post1080 Door glasshardware – Post1053 Door handlegaskets (NOS) #1154551 -Post 377 Door handleoriginal thickness vs. other years -Post 326 Door handlere-chromed and #9709600 push button -Post 374 Door handleready for installation -Post 700 Door hingearea painted – Post 20 Door hingebolts (3 different manufacturers) - Post20 Door keylock and gaskets - Post809 Door keylock original vs. Service replacements - Post1379 Door latchoriginals and door latch rod covers - Post508 & 1053 Door latchespainted – Post 1068 Door lightswitches - original -Post 700 Door lock originalpush knob – Post365 Door mirrortaking glass out for re-chrome -Post 585 Door mirrororiginal date code 10-DMI-7 - Post43 Door mirrororiginal restored and installed – Post1161 Door rubberbumpers - original -Post 700 Door rubberbumpers (NOS) #4721222 – Post1094 Door sillplates (NOS) with rivets purchased 1979 -Post 810 Doorweather-stripping (NOS) – Post1134 Door windowcranks - Post 540& 567 Door windowcranks assembly after re-chrome – Post881 Door windowfuzzies - https://www.camaros.net/forums/3414713-post1077.html]Post 1077[/url] Drag linkoriginal blued - Post208 Driveshaftpaint markings after Evaporust bath -Post 271 Driveshaftpaint markings installed – Post1409 Driveshaftyoke - paint markings -Post 285 & restoredPost 426 Driveshaftrestored - Post322 Drum brakehardware - Post 393& 395 Drum brakewheel cylinders rear -Post 276
E-F
Emblems -fender (NOS) 302, bezel and Camaro – Post959 Emblems -fender original 302 emblems Eddie had taken off car late 60’s – Post1317 Emblems - trunklid Fisher #7752901 - Post1361 Emergencybrake cables - Post401 & hardware413 Emissionssticker radiator support – Post1187, 1188,Post 1238 Engineassembly #3830711 head gaskets, pistons, heads, etc. -Post 506 Engine cam,Crane blueprint specification – Post1130 Enginecompartment original ‘68Z (cook_dw) with air cowl plenum - Post1004 Engine dressup starting - Post 582& 608 Engine dynosheet - Post 531 Engine headbolts original - Post481 Engine mount#6258154 (not correct purchased 1979) -Post 484 Engine mountcorrect - Post 500& Post 505 Engine mounthardware original vs. reproduction - Post482 & 539 Engine oil pandrain hole “TR” bolt - Post43 Enginepainting at plant picture -Post 646 Enginepiston original - Post412 Enginestamping pictures -Post 168 Engine withtransmission going in subframe -Post 735 & 736 ExhaustGardner installation – Post1168 Exhaust pipehanger rear originals - Post554 Fan shrouds,original vs. (NOS) Service replacement – Post1087 Fender sidemarker bezel differences – Post70 & 71 Flashersignal Stat 175 - Post783 & 785 Fuel pumpAC40524 used on ‘68 Z/28’s – Post1260 Fuel pumporiginal bolts - Post201 Fuel pumpplate, black or bare metal – Post872 Fuses colorcoded – Post 1294
G
Gas caplocking (NOS) #986970 – Post62 Gas caporiginals riveted handle -Post 373 Gas caporiginals riveted handle look added to NOS cap -Post 546 Gas pedal#3920296 review - Post365 Gas lineclip #3881339 clip with screw #3886522 & #3841230 -Post 586 Gas lineclip #3881339 install how to -Post 608 Gas tankanti-rattle strips – originals -Post 269 &1143 Gas tankfiller neck cover and phosphate screw – Post1014 Gas tankfiller neck hose and hardware - Post298 & 300 Gas tankfiller neck hose hardware clamps original - Post302 Gas tank fillerneck installation - Post1014 Gas tank installed– Post 1143 Gas tanksending unit original vs. #19179532 Service replacement -Post 520 Gas tankstrap - original semi-gloss black -Post 251 Gas tankstrap and bolts with nuts -Post 268 Gas tankstrap original bolt vs. reproduction -Post 275 & Post425 Glassquarter windows and trim – Post1053 Glasswindshield with rear glass and trim – Post1127 & 1128 Glove boxdoor Camaro script removal and parts – Post905 Grille endbracket installation with rivet – Post1144 Grilleinstallation – Post1117 & 1152 Grillematched for original look gray and painted – Post1144 Grille prepfor paint (NOS purchased 1983) - Post957 Ground atgauge cluster housing (speedo/tach) - Post1139 Ground strapscrews #9420415 - Post595
H
Hardware#124829 Z-bar nut – Post1315 Hardware#272876 shackle nut phosphate – Post1301 Hardware#3831892 - Post427 Hardware #3873852beside #3747933 carb studs – Post1013 Hardware#3933052 10-24X1/2” AMK correct – Post945 Hardware#5959164 rear tail-light screws – Post980 Hardware#9418962 console screw – Post1043 Hardware#9420415 ground strap screws – Post595 Hardware#9780422 three different suppliers - Post748 Hardware andfastener list by part number - Post1253 Hardware-fender clips - Post302 Hardware spoiler– Post 1087 (Foundlater to be acorn nuts!) Headergaskets made as GM originals -Post 508 &1301 Header GM hardware- https://www.camaros.net/forums/3940585-post1308.html]Post 1308[/url]& 1309 Headers-Kustomreproduction - Post263 & coated Post 279 Headlight bucketsoriginal restored – Post1119 Headlightelectrical connectors original -Post 309 Headlight T3date stamping original – Post39 Headlight T3testing - Post 884& installed Post1152 Headliner installed- Post 1080 Heater box andcore dated 67L - Post485 Heater hose –Post 995 &NCRS information Post1042 Heater hosewith GM logo picture taken Summer ‘68 (cook_dw) (Note: Heater hose for 68 used GM logo & by early 69 modelschanged to grooved) - Post1004 Hood bumpers- original vs. reproduction - Post1073 Hood hinge#3910668 comparison original to Service replacement -Post 269 &270 Hood hingeto fender screw differences – Post1254, 1255& 1256 Hood hinge andlatch restored - Post361 Hood hingehardware #9419301 - Post480 Hood latchparts - Post 256 Horn relayrestored - Post148 Hornsrestored by horn works - Post170 Horn screwsoriginal zinc - Post413 Hose clamporiginal - Post365
I-K
Idler armoriginal #3917581 and seal #5693027 – before and after -Post 204 Ignitioncoil bracket original vs. Service replacement - Post413 Ignitioncoil comparison - Post492 Ignitionswitch - pick it when you have no key – Post1379 Innerfenders NOS - layout for A-Arm flaps - Post1020 Innerfenders NOS - drilling for stapling rubber shields & making staples – Post1045 Intakemanifold bolts shouldered and non-shouldered -Post 581 Intakeoriginal #3017610 restored - Post664 Intake oilfill tube cap - original vs. Service replacement -Post 369 Intakethermostat housing – Post37 Interiorbucket seat catch stops restored – Post1251 & 1261 Interiorcarpet installation front – Post735 Interiorcarpet original tag – Post4 Interiordoor panel fuzzies (NOS) vs. reproduction – Post1143 Interiordoor panel installation – Post1156 & 1157 Interiorlace vs. reproduction – Post1191 Interior(NOS) package tray #7666129 – Post1134 Interior pillarpost seals original – Post349 Interiorrear view mirror original restored – Post1140 Interiorsail panels re-glued and installed – Post1097 Interiorseat belts – original - Post1142 Interiorseat belts - original Model 137 vs. Model 177 – Post1183 Interiorseat rear - Al Knoch issues – Post1191 Interior seatrear - correct burlap and spring & view from trunk – Post1251 Interiorseat rear - correct original cover installed – Post1297 Interiorseat track hardware original restored – Post1191 Interiorsill plates (NOS) purchased 1979 with rivets – Post1191 & 1232 Interiorwindow - vent knob repair and put back on after chroming – Post1303 Judging BowTie results – Post1232 & 1238 Keys-Briggs& Stratton - Post304 & 1249 Kick panelsOER installed - Post709
