Old 11-01-2020, 05:48 PM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
Well done!
Jake Dykstra
Dykstra Motorsports
Old 11-01-2020, 10:11 PM
Canuck's Avatar
Canuck Canuck is offline
Originally Posted by njsteve View Post
I also decided to reuse the original dashpad since there were only two minor cracks by the front speaker grill screw holes - a common occurrence. Since it is around $800 plus $200 core charge to get a reproduction dash... and none are available now, I decided there are better things to spend my money on...like vintage mag wheels.
I wound up using some JB-Weld epoxy and gently pushed it in to the cracks with a tiny screw driver. Once it was filled, I waited for it to cure and then sanded. I then sprayed the entire dash with SEM Landau Black interior dye (I LOVE that paint - I put that s@$& on everything!). Here's the results.
Not bad from a foot away or so and now I don't have to mess with transferring the vin tag to a new dash pad (Stupid Chrysler design - lets rivet the vin to a removable part!!!)
Nice repair job. Weird that Mopar riveted the vin to the dash,although rivited to the metal carrier on my 68 Dodge Charger it too is a removable part.
www.vancouverclassiccars.com
Old 11-06-2020, 03:23 PM
njsteve njsteve is offline
Well I took a couple days off the tinker with the new wheels.
First I had to wait for the Aluma-Brite to arrive. http://www.k-chem.com/msds/AlumaBrite.pdf
Its a hydroflouric acid detergent solution used in the detailing trade to brighten up raw aluminum - like boat pontoons and big rig fuel tanks. After carefully donning all my PPE, I sprayed it on the wheels full strength and let it sit on there and foam for about a minute. I then hosed it off with cold water. It repeated it a couple times and then really washed them off with soap and water for around ten minutes.
I then moved on to the shiny parts of the wheels. It took eight hours or so of hand-sanding to get the polished finish back on the spokes. The five holes are supposed to be in an as-cast finish.
Starting with 800, then 1000, then 1500, then 2000 wet paper. I hand sanded the hub area spokes and the outer small hub spoke sections that touch the chrome rim. VERY CARFEULLY, trying not to touch the chrome with the sand paper.
I have no finger tips left at this point but the rims came out great. I then masked off the outer area and painted the black out section with Rustoleum Matte Black paint.
Here's the finished set with the Polyglas F70x14s mounted. Sorry I couldn't pull it out of the garage but there's no steering wheel or dash in it at the moment.
The Following 9 Users Say Thank You to njsteve For This Useful Post:
1967Z28 (11-07-2020), 427TJ (11-06-2020), big gear head (11-06-2020), gtomike1967 (11-07-2020), olredalert (11-07-2020), PeteLeathersac (11-06-2020), ScottG (11-19-2020), Xplantdad (11-06-2020), ZLP955 (11-10-2020)
  #794
Old 11-06-2020, 03:29 PM
Looks great Steve!!
Old 11-06-2020, 06:11 PM
RPOLS3's Avatar
Wow
Jake Dykstra
Dykstra Motorsports
Old 11-06-2020, 06:21 PM
scuncio scuncio is online now
That car looks incredible. Did you use the alumabrite on the as-cast areas of the wheels, then?
Old 11-06-2020, 06:26 PM
Awesome.
Old 11-06-2020, 07:07 PM
Yes, that was the main purpose of using the Aluma-Blast - to clean the cast areas since there really isn't anything you can use on it that won't alter the appearance of the cast areas - I guess you could media blast it, but you'd have to mask off everything around the cast areas. It was hard enough masking the center portion to spray it black.
scuncio (11-07-2020)
  #799
Old 11-06-2020, 08:34 PM
mssl72's Avatar
mssl72 mssl72 is offline
Looking good!!!
Mark
1966 L72, 4spd Caprice
1974 Z28, M40 Camaro
Old 11-07-2020, 12:47 PM
Woj's Avatar
Woj Woj is offline
Very nice Steve!
