Old 07-17-2023, 01:30 PM
RPOLS3's Avatar
RPOLS3 RPOLS3 is online now
Default 62 - 409 starter question
I posted this over at the 348/409 site but looking for help here as well.....
I purchased a restored dated starter for our 62 409. It appears that the incorrect starter currently in the car bolts in with 3 vertical bolts from the bottom of the starter into the block - the correct restored starter bolts with 3 horizontal bolts into the bellhousing. Do I now just need the correct hardware for the bellhousing mounts or anything else?
Don't mind the custom road draft tube bracket....
Thanks in advance.
Jake Dykstra
Dykstra Motorsports
Attachments - The Supercar Registry IMG_4570.JPG IMG_4569.JPG IMG_4568.JPG IMG_4567.JPG
Old 07-17-2023, 01:39 PM
I don't see where your current bellhousing will accommodate 3 fasteners, only 2. Didn't the '62 have a cast bell ? I can look at the one I have here and see if it has 3 mounting holes.
McCune McCune is online now
The new flange style starter is for a Manual Transmission.
Old 07-17-2023, 03:12 PM
John Brown's Avatar
This shows the three bolt holes.
John Brown
69M22Z (07-17-2023)
Old 07-17-2023, 04:52 PM
Ah, the bottom hole is in the casting but couldn't see it from the back.
Old 07-17-2023, 06:54 PM
RPOLS3's Avatar
Is the one in the car now for an automatic then?
Jake Dykstra
Dykstra Motorsports
McCune (07-17-2023)
Old 07-17-2023, 08:32 PM
John Brown's Avatar
I know for a fact that the bolt to the block style starters were used when a Turboglide was installed, as far back as 1957.
John Brown
The Following 2 Users Say Thank You to John Brown For This Useful Post:
dykstra (07-17-2023), RPOLS3 (07-17-2023)
Old 07-17-2023, 10:20 PM
Yes, according to my part book.
Old 07-17-2023, 11:50 PM
John Brown's Avatar
If you want the starter to be more correct looking, originals had a pin going through the fork that was held in by a snap ring, not a bolt and nut affair.
John Brown
dykstra (07-20-2023), RPOLS3 (07-18-2023)
Old 07-18-2023, 12:19 AM
RPOLS3's Avatar
Thanks - do you have a picture of what that looks like?
Jake Dykstra
Dykstra Motorsports
