Old 10-14-2024, 02:15 AM
Default Fuel Pump Cosmetic Restoration ?????
GOAT HILL Screwed me on Restoring Two AC/Delco Dated OEM Fuel Pumps, when they did
the Bottom Portion in Clear (Silver) Zinc rather than Yellow Zinc Dichromate.........
I was "thinking" I could find a shade of "Gold" Powder Coat at PRISMATIC Powder
and have the Bottom Metal done this way.............
Any thoughts other than NO ??????
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
Attachments - The Supercar Registry Zinc plating gas cap.jpg PXL_20250620_205900701.jpg PXL_20250620_205841914.jpg PXL_20250620_205758887.jpg
Old 10-14-2024, 03:26 AM
juliosz's Avatar
juliosz juliosz is offline
Awesome work by this gentleman:
Fred Ballard
28916 Flowerpark Drive
Canyon Country, Ca. 91387-1801
661-251-2362
[email protected]
The Following 2 Users Say Thank You to juliosz For This Useful Post:
napa68 (10-14-2024), X66 714 (10-14-2024)
Old 10-14-2024, 04:27 AM
X66 714's Avatar
X66 714 X66 714 is offline
100% Fred Ballard.
Sadly Goathill screwed me also. Nobody should've ever got screwed again by Goathill. Plenty of info here about it....Joe
SS427 (10-14-2024)
Old 10-14-2024, 06:23 AM
Tuna Joe Tuna Joe is offline
Only thing about Fred is that it will take a long time if you are having plating done.
This December will be a year since I sent mine to him.
I expect to get an email any day now that it’s on its way. ( fingers crossed)
The Following User Says Thank You to Tuna Joe For This Useful Post:
juliosz (10-14-2024)
Old 10-14-2024, 12:44 PM
L16pilot L16pilot is offline
I would be concerned about the effects of the bake temp of powdercoating on the internal diaphram.
Steve Nuwer
1970 Z28, Norwood 03A, 48 48, 723 Int, M20, COO, 2021 Legends Platinum restored
1970 L78, Norwood 04C, 17 17, 711 Int, M21, COO, born-with drivetrain project.
1972 Z28, Norwood 11C project, born-with drivetrain, 26 26, 775, M20, CGG project
1970 Z28, Norwood 05C, 48 G, 720 Int, M21, COZ, Original Unrestored (SOLD)
www.2ndGenZ.com
The Following 2 Users Say Thank You to L16pilot For This Useful Post:
dinograz (10-14-2024), SS427 (10-14-2024)
Old 10-14-2024, 03:10 PM
If a person were careful and plugged the openings well, I see no reason why you could not zinc plate with a gold dichromate finish just the bottom without disassembly. You may have to build a jig to hold it perpendicular to the zinc bath. Caswell can set you up with a kit.
Gas cap example:
Owned since 1978 - First Car
Old 10-14-2024, 07:24 PM
169indy's Avatar
169indy 169indy is offline
The coated item is then oven-cured at temperatures around 350 to 400°F (176.6 to 204.4°C). The high heat melts the powder, creating an even, smooth coating.
I concur Bad Idea given the soft goods internal to a Fuel Pump.
Now the Plating Idea would possibly be a easier route, think about it.
It is Already Brite (Clear) silver Zinc, All it would need is the Dichromate post treatment, that would not require rectifier hook up just a Dunk and Dip and Rinse.
Nasty Stuff.
My Plater source (Edmonds-Everett Guy doing Planes stuff after all he is kind of Slow right at the moment *Strike effects) would tell me to take a Hike and Jump off a cliff when bringing him such a "Risky" item (To Him).
Go Get a Fluorescence Yellow Highlighter from Office Maz and Do a Test Swipe, that Might Yellow it up enough- Backyard Hack maybe, You Just Never know.
The Eastwood Paints might be able to be misted on over it to trick some, but usually I DO NOT bother with Poof Can plating.
I was a Caswell user 20 years ago but found at time commercial platers WILL help out, but thier moods change with the times.
69 Los Z11
68 SS/RS 396/325
68 Los Z28
Old 06-05-2025, 04:38 AM
I had my GOAT HILL incorrectly plated 40726 AC Pump plated with Yellow Zinc on the Steel Fuel Section...............
Now Im asking for a conclusion on how best to refinish the cast Aluminum Portion....
Glass Bead and Spray with Clear ???
OR What's Your "Secret"
Bottom Pic is Service Replacement that Id like to replicate the "LOOK"
Chuck Sharin
[email protected]
Old 06-12-2025, 04:38 AM
On the above pictured pump , I glassbeaded the cast aluminum "top" section so its
clean but I dont like the look.........
I dont have a can of Eastwood/Seymour AlumiBlast .....Any thoughts on
what aeresol I could mist on the glassbeaed aluminum to make it look
"good"
This pump cosmetic restoration has turned into a ugly project.........but
I'd still like to have the date coded pump on my 70 Z28 .............
Chuck Sharin
[email protected]
Old 06-12-2025, 08:13 AM
TimG TimG is offline
Fred is the guy, he does great work.
