Old 09-27-2009, 09:46 PM
Default MIR
Jerry MacNeish won Best Engineered Race Car at the IHRA Presidents Cup race at MIR recently. Also won his class with his 1967 Z/28 in D/S. Car is starting to run real good in Stock Eliminator. Header, clutch and some suspension modifications are starting to pay off. You can see his 10.73 run at Cecil if you type his name in on YouTube! Turn the volume up!
Old 09-28-2009, 03:11 AM
x  Baldwin  Motion's Avatar
Default Re: MIR
https://www.youtube.com/watch?v=jl5dG...eature=related
Old 09-28-2009, 01:45 PM
TDW TDW is offline
Default Re: MIR
Nice. There's a guy that "walks the walk", not just a "talker". Impressive, to say the least.
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
Old 09-28-2009, 02:35 PM
bbbenny bbbenny is offline
Default Re: MIR
The guy can, drive a car. Thats what these cars, where built to do. In the day. BBBenny
Thanks Benny
Enjoy; orginal cars,with orginal drivetrains and docs. bblocks are my favorite.
Old 09-28-2009, 02:56 PM
Default Re: MIR
YEP, Actually he is pretty good on the tree! Atco this weekend and then The Dutch Classics at Maple Grove. I bet the car dips into the 50's with this good air. NHRA doesn't give much of a break to the 302's.
Old 09-29-2009, 03:43 PM
SSRSBOB SSRSBOB is offline
Default Re: MIR
That's incredible! And a stock 302?
Bob
Old 09-29-2009, 05:25 PM
Default Re: MIR
Well, NHRA stock which is more stock than superstock!
Old 09-29-2009, 05:49 PM
Default Re: MIR
Read the rules, cam has to be stock lift, .485 for Z28, no head work, stock intake, rocker arms, valve springs, carb, rods, pistons, crank, etc. That is flat out flying! Car has to weigh 3100-3200 lbs with that little 302?
Bob
Old 09-29-2009, 09:50 PM
Default Re: MIR
No stock duration. Valve springs are stock appearing but way stronger, the clutches are about $3,000 along with the headers and the Jerico 4 speeds are around $4,000. Rocker arms, crank, rods, carb etc are not slowing it down. The intake may take a few hp away but not much. I believe??? they all acid port the heads because everybody does so who cares. Also the ignition is much better. Ask Jerry what his compression ratio is. I bet it is not 11 to 1. Yes, all in all a very fast motor and car but not as stock as the average Joe thinks. Stock eliminator has come a long way and so has the research and development. Look how fast the 350/255 horse camaros and novas are. In the 10's with a Q-jet, cast iron intake and a mush lifter cam! Thats moving! Jerry is running down Atco this weekend I think. If the air is good and he can get hooked I am hoping to hear that he ran in the 10.60's or maybe in the high 50's.
Old 09-29-2009, 10:00 PM
Default Re: MIR
Wow - that's cookin'!! So what do the smart guys think his HP and TRQ are?
