Old 12-01-2009, 04:02 AM
1968 nova ss 1968 nova ss is offline
Default 2005 chevy silverado /speedo
My speedometer on my 2005 chevy silverado went from a cruisin speed of 70 and then it went instantly to 120mph ans stayed stuck there for a few days .now when I start it up some days it s on 10mph others days 40mph or whatever.It is working ,just not correctly.any ideas.chris
Old 12-01-2009, 05:13 AM
bpodner bpodner is offline
Default Re: 2005 chevy silverado /speedo
There was a tsb for GM instrument clusters a while back, don't know if it's still valid. The speedo did the same thing on my 03 Z71 Suburban. After going round and round with the dealer, and reporting it to the NTSB, the tsb finally came out. The work around is to cycle the ignition key on/off, this brings the speedo down to 0 in 5 mph increments. There used to be a guy on ebay that rebuilds the clusters for a lot cheaper than GM, try a search he had a lot of good feedback. The stepper motors are what goes bad.
By the way, that vehicle was the last GM vehicle I ever bought, a $50000 POS.
Old 12-01-2009, 05:24 AM
TORONADOXS TORONADOXS is offline
Common problem. Replace the cluster and move on. It will also need to be programmed, if you are thinking of doing it at home.
Old 12-01-2009, 05:27 AM
Chateau Slate 66 Chateau Slate 66 is offline
x3... cluster
Old 12-01-2009, 05:39 AM
YenkoYS-199Stinger YenkoYS-199Stinger is offline
I have the same problem with my 05' Duramax and my tach does the same too. Sometimes I have one or the other and sometimes neither.
Chris
1966 Yenko Stinger YS-070
1967 Yenko Stinger YS-199
1969 Yenko Stinger YS-320
Southeast of Disorder
Old 12-01-2009, 05:48 AM
MosportGreen66's Avatar
My '03 Yukon did the same thing at around 85-90k miles.
Old 12-01-2009, 05:55 AM
ORIGLS6 ORIGLS6 is offline
I'm dealing with the same issue. On my way to Rosemont I glanced at the speedo and was shocked to see I was running 135 @ 2200 RPM.
Below is a link to a guy who repairs them for $169 ($189 for the entire cluster) including shipping BOTH WAYS!
In the mean time there's a 'reset' proceedure you can do. Turn on the ignition and click the key forward just shy of engaging the starter. Each time you do this the speedo needle will work its way back toward zero. It may take five to twenty clicks depending on where the needle sits. Mine works correctly for days, then out of the blue it goes nuts again. And most recently, it worked its way back to zero on its own! Go figure. And FWIW, my local dealer told me I'm looking at $600 to $800 for them to do the fix.
Go here.
Old 12-01-2009, 06:33 PM
Jonesy's Avatar
Jonesy Jonesy is offline
I used this guy in Minnesota. Turnaround was 3 days. lifetime warranty for $125.
507-429-4489 OR EMAIL AT [email protected]
Dave Ruberg.
http://cgi.ebay.com/ebaymotors/GM-SLIVER...sQ5fAccessories
Old 12-01-2009, 06:36 PM
Jonesy's Avatar
They are easy to take out and unplug by yourself. You can also still drive the vehicle without it. I used my GPS for figuring out my speed. Got it back and put it back in. was virtually painless.
Old 12-01-2009, 06:49 PM
And FWIW, my local dealer told me GM is covering the '04s up to 90K miles, but the '05 models up to 100K. Seems strange to me but then common sense is pretty rare these days!
