Old 01-14-2010, 04:03 AM
71-LS6 71-LS6 is offline
Default Is this a 1967' 302 engine?
My buddy just pulled a small block out of a 57' 210 coupe that he pulled out of a cow pasture. The block & head numbers show to be a 1967 302 or 327 with 2.02 intakes & 1.6 rockers. Is there any way to tell if this was a Z-28 powerplant or did it come from a Corvette?
Steve H.
industrial art collector
Old 01-14-2010, 04:04 AM
67L78conv 67L78conv is offline
Default Re: Is this a 1967' 302 engine?
are there any numbers stamped on the pad?
Old 01-14-2010, 04:08 AM
Wait, have you see the valves or are the just 461 heads?
Jason
Old 01-14-2010, 04:09 AM
markjohnson's Avatar
Take a quick glance and see if it has the very large, High Perf Harmonic Balancer.
Old 01-14-2010, 04:31 AM
Block is 3892657, heads 3890462 w / D 2 67 casting date? deck pad VO428HC? I'm not a small block guy and none of these #'s are familiar at all to me. I was just looking for some correct heads on my original block, 327 Camaro.
Steve H.
Old 01-14-2010, 04:54 AM
JChlupsa JChlupsa is offline
is there a partial VIN stamped on the engine pad?
no HC Engine code for 67/8/9 Camaros and I dont see any HC code for vettes either, could it be HO?
67 Z would have MO or MP engine code not HC
3892657....302.....67....2...Z-28 Camaro
3892657....327.....67....2
3892657....350.....67....2...Camaro
3890462....66-67...302/327/350..Camel hump,no accessory holes,64cc chamber
Old 01-14-2010, 05:36 AM
He's going to re-check the deck stamping, the balancer, and the pad on the tranny also. They are double hump heads.
Thanks, Steve
Steve H.
Old 01-14-2010, 06:59 AM
HC = 327. 275 horse with a powerglide. Full size car.
Old 01-14-2010, 07:21 AM
That is what I was thinking it would be. The heads having 2.02 valves it what threw me. I imagine hey were going by casting numbers only. Those heads can have 1.94 or 2.02 valves.
Jason
Old 01-14-2010, 05:24 PM
If you car is a 327 275 then they would be the correct heads. If it is a 327 210 then it would have the lower hp heads.
