Old 03-06-2010, 08:40 PM
df396 df396 is offline
Default ZZ 454 exhaust valve height
I have a ZZ454 that we are about to drop in a 69 SS Chevelle. i was checking the exhaust valve placement in comparison to the steel heads that are on the old motor and the measure 1/2" higher than the old heads. i had a pair of Hooker super comps for the car but after calling Holley and asking if the would work they said no. Has anyone out there put a ZZ454in a 69 Chevelle and what headers did you use? Would manifolds work with the tall deck? I would really prefer to use headers with this motor. Also, if someone has done this did you put the headers in from the bottom, or set the motor in with theheaders tied back on the wheelwells in the engine compartment? This is a power steering car, and the head bolts have been machined to accomodate headers
Thanks,David
Old 03-07-2010, 06:35 PM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
Default Re: ZZ 454 exhaust valve height
I just responded to your other thread on the same topic. I used the factory exhaust manifolds on my swap and had no issues. One of my obejectives was to keep a stock look so I painted the aluminum intake orange and installed the factory exhaust manifolds with the smog system intact.
Jake Dykstra
Dykstra Motorsports
Old 03-09-2010, 04:56 PM
COPO 70 RS/Z28 COPO 70 RS/Z28 is offline
Default Re: ZZ 454 exhaust port height
Hey Jake
df396 used to ride around with me in you Dad's 09.
Carl
Old 03-09-2010, 06:31 PM
RPOLS3's Avatar
How cool is that?
Dad's been steadily improving it this winter and I hope to have a ride (and drive) this spring sometime.
Jake
Jake Dykstra
Dykstra Motorsports
Old 03-09-2010, 06:44 PM
Great to hear, is he going to change out the tires!!!
I still need to get that part in the mail to him!!!
Carl
