Old 04-26-2010, 09:59 PM
ALLZS ALLZS is offline
Default DRILL & TAP FOR SMOG TUBES
DOES ANYONE KNOW OF SOMEONE THAT CAN CORRECTLY DRILL & BOTTOM TAP A NON AIR EXHAUST MANIFOLD OVER TO A AIR TYPE ?
Old 04-27-2010, 12:17 AM
Don_Lightfoot's Avatar
Don_Lightfoot Don_Lightfoot is offline
Default Re: DRILL & TAP FOR SMOG TUBES
I'm getting one manifold done right now, should be done this week I hope. Having a local machinist do it who has been around for a long time and is a car guy as well (into building dragsters). Took an A.I.R. manifold in for reference. I realize I'm certainly not in your area, but will let you know how it came out.
Specialized Chevrolet Decals
Old 04-27-2010, 12:39 AM
SS427's Avatar
SS427 SS427 is offline
I have them done all the time. Typically costs me about $100 a pair and looks great when completed. It is not rocket science to a machinest and with a donor manifold and an asperator tube to show them, it is actually quite easy. Your engine builder should be able to do this. If I am not making the A.I.R. functional, I have them stop the hole short of going all the way. This way I do not need to block it myself. Make sure they chamfer the opening on the outside like the original as this is often missed.
Rick Nelson
Old 04-27-2010, 01:39 AM
VintageMusclecar's Avatar
Rick;
Clean out your PM box please [img]<<GRAEMLIN_URL>>/smile.gif[/img]
Eric
Old 04-27-2010, 02:00 AM
ALL CLEAN !!
Old 04-27-2010, 02:22 AM
[img]<<GRAEMLIN_URL>>/blush.gif[/img]
Wrong Rick...was talking to Rick Nelson.
Old 04-27-2010, 02:39 AM
firez firez is offline
Can anyone tell me what tap I need to buy to do the AIR holes?
1968 LOS Rallye Green Z28
Old 04-27-2010, 03:10 AM
acelr8 acelr8 is offline
1/4 straight pipe NOT taper pipe.Jeff
Old 04-27-2010, 03:34 AM
Thanks
Old 04-27-2010, 01:26 PM
FANTASY FACTORY FANTASY FACTORY is offline
Also needs to be machined for inverted flair, unless there is a drop in seat available now.
