Old 07-05-2010, 05:27 PM
Tom Hartman Tom Hartman is offline
Default Temperature Sender
I have recently put together two cars for friends. One is a '69 SS 396 and the a '69 "Z". Both cars have consoles with gauges. The problem is both cars show they are running hot on the gaugeither car has overheated, just run up in the red on the gauge. I used aftermarket senders that have a blade terminal instead of the factory eyelet. When I changed the wire over, did I screw up the continuity in the wire? Thanks in advance, I am stumped.
Tom
I should have added, both cars are stock builds with new thermostats and clutch fans with shrouds.
Old 07-05-2010, 05:49 PM
Donnie's Avatar
Donnie Donnie is offline
Default Re: Temperature Sender
get the sender with the stud and nut.
I had the same problem with the push on blade type.
69 SS L78 Chevelle
70 SS 396 Chevelle
Old 07-05-2010, 08:57 PM
budnate's Avatar
budnate budnate is offline
guy on ebay supposedly sells the right one, claims it will read right, I bought one but have not used it yet.
Old 07-05-2010, 09:02 PM
njsteve njsteve is online now
This is a similar problem with the Pontiacs: all the aftermarket senders are essentially calibrated for the idiot lights even though they sell them to fit the cars with gauges. So they read waaaaaay high. I am currently hunting for the right sender for my T/A which at the moment reads 210 when it is actually 170 (checked with an actual thermometer).
Read here:
http://forums.performanceyears.com/f...d.php?t=632070
This company supposedly sells a correct sender:
http://www.lectriclimited.com/mainpage.htm
Old 07-06-2010, 01:20 AM
Sound like I need a couple senders. I will order the ones on-line and let you know how they work. I thought there had to be a connection with both cars having the same problem. Thanks again for the advice and the link.
Tom
Old 07-06-2010, 01:52 AM
Yes, please update us the minute you get one installed.
I'd love to know that someone is making the right sending unit out there, somewhere!
Old 07-16-2010, 02:02 PM
Audric Audric is offline
I have had the same issue with my 73 T/A, I bought from NAPA, Autozone, Checkers, and even Classic industries to no avail! Still reads like it is going to overheat. I will wait for your test on the lectriclimted!
Old 07-16-2010, 02:57 PM
Steve Shauger's Avatar
Administrator
Wells manufactures a replacement sender that is virtually identical to the original sans the AC and made in the US script. The part# is TU12 and they work perfect and have been using them for years. Autozone sells them and i bet that where Letriclimited procures their senders.
www.yenko.net
www.vintagecertification.com
Old 07-16-2010, 03:35 PM
Keep in mind too that most temperature senders are positioned in the head,so you're reading an upper head temp. & not a realistic block temp.
Head temps run much higher then the block,and are not always accurate to what is really happening.
Old 07-17-2010, 01:21 AM
Well, I bought one of the Lectric Limited senders, installed it in the cyl head in the factory spot and it reads 25 degrees higher than the radiator water temperature measured with an accurate thermometer dipped into the coolant.
So much for the accurately calibrated reproductions. [img]<<GRAEMLIN_URL>>/thumbsdown.gif[/img]
The explanation provided above, that the cylinder head will give a higher temp reading than the block location may be true, but that doesn't explain the accuracy of the original factory senders. Were they undercalibrated to compensate for higher cyl head temps?
