Old 11-02-2010, 11:06 PM
StealthBird StealthBird is offline
Default Re: 72 TA : New Project
Congrats Steve! I received my HMM last Saturday, and it's a very nice write up on your project. I also thought it was pretty cool that at the end of the article, they actually print a link to this forum, and this thread, for more info!
Such a great looking car! The 72 Trans Am, with the honeycomb grilles and honeycomb wheels, is just a beautiful combo.
[img]<<GRAEMLIN_URL>>/Can-I-Have-It.gif[/img]
1959-1980 Pontiac Window Sticker Reproductions : PontiacWindowStickers.com
DVD's for Musclecar fans! MusclecarFilms.com
Old 11-12-2010, 01:54 AM
njsteve njsteve is offline
Got the proportioning/combination valve back from one of the Performance Years website members, 70RAIII (Bill Oxley) who did a really nice job rebuilding it. He indicated that it was all stuck inside, so it wasn't really functioning as anything other than a T-fitting between the front and back fluid routes. Now it's actually working as designed, which is a good thing since if I recall correctly, one of the critical roles of this valve is to internally shift and block the internal passages if one circuit springs a leak and loses fluid. That way you still have braking power for the remaining circuit.
Another thing I noticed is that the purple DOT 5 silicone brake fluid turns yellow after a few years. Even the leftover, half a bottle I still had on the shelf, turned the same yellow. I'd imagine that means it's time to replace it all, which I did. I flushed the entire system and replaced it with new DOT 5 silicone brake fluid, about four bottles worth, to get all the old stuff out and completely flush the system of the four year old fluid.
The newly refurbished proportioning/combination valve, just back from Bill Oxley:
And after the installation and the brake bleed-a-thon:
