Old 01-19-2011, 02:15 AM
Berger RS Copo Berger RS Copo is offline
Default BE axles
Looking for help with identifying factory axles for a BE 12-bolt. Thanks for any help.
Old 01-19-2011, 03:29 PM
enio45 enio45 is offline
Default Re: BE axles
Very good question......anxiously waiting for the experts to chime in on this.
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 01-19-2011, 03:41 PM
m22mike's Avatar
m22mike m22mike is offline
I believe the axles were not different from the standard 12 bolt. Just the goodies inside the carrier. [img]<<GRAEMLIN_URL>>/dunno.gif[/img]
It's cold... [img]<<GRAEMLIN_URL>>/frown.gif[/img]
Old 01-19-2011, 04:20 PM
Mike I think they were shorter just like axles used with C clip elminators. Also the org. ones are different then the over the counter. I had a pair of NOS over the counter ones years ago.
If memory serves me right they shorter 1&quot; or more.
Jake is my grandson!!
Old 01-19-2011, 04:52 PM
William William is online now
There is no difference in production axle shafts for non JL-8 12 bolt axles. BE was the same as any other. A drag racer bud told me that service replacement axle shafts would not last nearly as long as production parts. Those may have used different steel or heat treat.
JL-8 axle shafts were physically different.
Old 01-19-2011, 06:17 PM
PxTx's Avatar
PxTx PxTx is offline
Did any of the 12 bolts use a larger lug stud than the standard 7/16&quot; we typically see? I had a set of axles once that had 1/2&quot; studs, but suspect someone did this on their own.
Paul III
Old 01-19-2011, 06:51 PM
Fast67VelleN2O's Avatar
I have seen some over the counter GM shafts that were not as tapered as other shafts and were larger in diameter. I would think that the larger shafts with less taper would be stronger?
Day 2 is Life.
Old 01-19-2011, 11:48 PM
Thanks guys. Both of my axles are stamped 2149. Could this be a build date? It's an 02D built car.Thanks again.
Old 01-20-2011, 12:52 AM
Wow I thought the Question was about jl-8's. Need a change in my glasses script. Sorry about that. [img]<<GRAEMLIN_URL>>/dunno.gif[/img]
Old 01-20-2011, 01:08 AM
No, you need a change in the brand of whiskey you drink! HA!
