Old 10-10-2011, 10:07 PM
SS427's Avatar
SS427 SS427 is offline
Default Re: Next Years Power Tour Car
Because some of us have a different definition of "mint"....
Rick Nelson
Old 10-10-2011, 10:28 PM
napa68 napa68 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: kwhizz</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Charley Lillard</div><div class="ubbcode-body">Looks like about 8 more bolts and that body lifts right up off that frame.... </div></div>
Why would a guy want to take the body off the frame of a &quot;Mint&quot; survivor car.........Just say'in </div></div>
Yeah, you would mess up those mint stencils and chalk marks!
Old 10-11-2011, 07:54 AM
jannes_z-28's Avatar
jannes_z-28 jannes_z-28 is offline
Since you changed the bodybushings it's a question of definition, I'd say you have had the body off of the frame. Maybe not all bolts were off at the same time but the body has been separated from the frame IMHO.
Jan
Jan Suhr
Stockholm, Sweden
1969 Camaro Z/28 ProTouring
My Car My Book My Photos
Old 10-11-2011, 02:33 PM
kwhizz kwhizz is offline
Stopped by the body shop today to see when they would be ready for me to bring the body there.....They are still busy but maybe towards the end of next week........I have plenty of time so it's not a big deal.......I ordered up the 4 wheel Brake system yesterday.......gonna order the suspension upgrades next week.....and I making a list of all the other &quot;Stuff&quot; I'm gonna need....Interior Kit, Weather Seal Kit...Bumpers should be coming back soon from the Plater...Dash Pad is finished and on it's way from Just Dashes.....They just had a couple of parts at the body shop prepped.......
Old 10-15-2011, 12:37 AM
Still waiting for my &quot;Slot&quot; at the Body Shop.......Ordered all the Suspension stuff.....Front and rear Tubular control arms with Coil-overs in the front and lowered springs in the back.............This is the Boring part.....Waiting....232 Days......
Old 10-15-2011, 12:53 AM
that's when you lock yourself in the basement and clean all of those boring little parts. hard to do when you want to hang big cool parts.
MCACN ir right around the corner Ken!
Old 10-15-2011, 02:16 PM
Not Cold enough yet to start with the basement stuff........LOL
Old 10-19-2011, 02:41 AM
Some of the purchased parts are starting to show up.......After doing the LS Swap in the 37 Ford, I was very happy with the way the Fuel system worked out....I used the GTO fuel pump/sender assy..........the GTO set-up does not required a Pressure regulated return line as it is a self-contained unit.......So.....
The new fuel tank showed up today and I brought a Fuel pump down to figure it out..........
New Tank
Tank and GTO Pump assy.........LOL
Hummmm!!!!! Now I just need the Pump assy to fit....I don't need the float arm function as I will be using the stock Impala Fuel Gauge sender.....So.....We need to get it as compact as possible......
I am just going use the original top of the pump to seal to the yet to be fabricated flange that will be welded into the tank and for the internal pump harness plug to connect to the external harness....All the existing GTO gas tank venting will be removed and sealed off .......It seems that everything will fit with a small sump area added to the bottom of the tank.......Ahh!!!.......The Fun starts
Before and after.........
228 more days
Old 10-19-2011, 05:44 AM
And the fun starts again!
Old 10-20-2011, 07:59 PM
Just got a call from Tri City plating......The Bumpers are finished and being shipped back.....The 4 wheel Disc Brakes are here, and the RideTech Coil over Suspension set-up just shipped out........Now....I need to get the Body into the Body shop.....But....they are still &quot;Slammed&quot;......Darn!!
