  #11
Old 10-19-2011, 02:41 AM
kwhizz kwhizz is offline
Default Re: Next Years Power Tour Car
Some of the purchased parts are starting to show up.......After doing the LS Swap in the 37 Ford, I was very happy with the way the Fuel system worked out....I used the GTO fuel pump/sender assy..........the GTO set-up does not required a Pressure regulated return line as it is a self-contained unit.......So.....
The new fuel tank showed up today and I brought a Fuel pump down to figure it out..........
New Tank
Tank and GTO Pump assy.........LOL
Hummmm!!!!! Now I just need the Pump assy to fit....I don't need the float arm function as I will be using the stock Impala Fuel Gauge sender.....So.....We need to get it as compact as possible......
I am just going use the original top of the pump to seal to the yet to be fabricated flange that will be welded into the tank and for the internal pump harness plug to connect to the external harness....All the existing GTO gas tank venting will be removed and sealed off .......It seems that everything will fit with a small sump area added to the bottom of the tank.......Ahh!!!.......The Fun starts
Before and after.........
228 more days
