Trim Tag Code 19 19
The Hi-Po big valve heads for the W30 have and 'F' cast into them.
The Julian casting date...looks like 335, so that would be the 335th day of 1969 on this particular W30.
The last three digits of the head casting number.
1970 W30 Head casting number is 404438. ![]() |
1970 W30 Distributor coded for manual trans, number 1111977 dated,
9G21 or July 21 1969 ![]() |
1970 W30 Intakes are cast aluminum and the words "Oldsmobile W-455" are cast on to the intake. For 1971, the casting was changed to read "Olds-W-455." Some late 1970 cars are said to have, "Olds W-455" cast on the intake.
This intake may not be correct for an early 1970? ![]() ![]() |
1970 W30 Manual Trans Carburators are coded; UA part number 7040256
This one is dated; 3509 or the 350th day of 1969. ![]() |
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Stefano</div><div class="ubbcode-body">1970 W30 Intakes are cast aluminum and the words "Oldsmobile W-455" are cast on to the intake. For 1971, the casting was changed to read "Olds-W-455." Some late 1970 cars are said to have, "Olds W-455" cast on the intake.
This intake may not be correct for an early 1970? ![]() ![]() Turns out that the intake is correct for this W30. "Cars built after 3 Jan 70 should have the OLDS W-455 intake. We have never seen a December BUILT car have one. The earliest casting dates are in the mid December time frame. The Early OLDSMOBILE W-455 intakes are some of the hardest to locate. We have also seen date codes as early as 13 Aug 69 on the Oldsmobile intake. " |
here's a pic of the W-30
Panther Pink 440-6 Shaker Challenger 1970 |
Another
