  #11
Old 11-13-2011, 06:54 PM
67BobcatGTO 67BobcatGTO is offline
Default Re: Mallory Ignition Parts
Ok well I finally had some time to dig through my literature and found sales lit on the "NEW" Rev-Pol models.
It states this:
The Rev-Pol ignition system changes the direct current to alternating current, which produces a complete reversal of the polarity of the core of the transformer, which in turn produces a long magnetic wave inducing a spark of long duration and of high value every time the contact point open and close. The contact life is twice as long, the rubbing block life is twice as long as in the conventional system. The system will operate any motor to speeds far above the conventional system on less current.
It also states the Rev-Pol distributor uses a 4-lobe cam with two circuit breakers for the 8 Cylinder and a 3-lobe cam for the 6 cylinder distributor, giving unlimited RPM with no breaker bounce.
-Mike
