Old 12-14-2011, 04:29 AM
whitetop whitetop is offline
Default Re: Tunnell Ram Toppers
Weiand intake but it gives you an idea what the stacks will look like on a BB. It is very symetric.
Old 12-14-2011, 04:54 AM
Hemicolt Hemicolt is offline
Good idea Dave.
These have the round holes. They may need to have the diameter trimmed down.
I guess the retaining ring can be made out of flat aluminum.
http://www.ebay.com/itm/Chrome-velocity-...ies&vxp=mtr
Old 12-14-2011, 05:14 AM
mr.4speed mr.4speed is offline
those are the ones i got new from jegs and had them gold anodized.
4 gear 4 life!
Old 12-14-2011, 03:09 PM
VintageMusclecar's Avatar
FWIW, re: those air filters with the black "foam" type filter elements;
Over the last ~30 years I have serviced more carbs than I can count that were fouled by that black foam after it dissolved and "melted" (for lack of a better term) into the carb. Getting that material out of the air bleeds is a real picnic.
I'm not sure what causes this (aside from the obvious carb backfires and subsequent fires), and I've seen plenty of cars that have ran those filters w/o issue, but I feel I would be remiss in my duties here if I didn't at least post a fair warning based on my personal experiences.
Just a heads-up. Carry on.
Old 12-14-2011, 03:48 PM
Good info Eric. We appreciate it. How are things to the west?
Old 12-14-2011, 03:58 PM
Guest
Posts: n/a
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: VintageMusclecar</div><div class="ubbcode-body">FWIW, re: those air filters with the black &quot;foam&quot; type filter elements;
Over the last ~30 years I have serviced more carbs than I can count that were fouled by that black foam after it dissolved and &quot;melted&quot; (for lack of a better term) into the carb. Getting that material out of the air bleeds is a real picnic.
Just a heads-up. Carry on.</div></div>
Ditto....I was in a Chevy dealer getting my SS Chevelle serviced (warranty work...) in 1970. Another local was attempting to get warranty work done on a '69 SS Nova (L78) with one of those foam filters. The engine had &quot;sneezed&quot; and melted foam was all over the Holley... L-O-L. Dunno if he got warranty. I did (killed a TH400 on the GM 5-Year, 50,000 street race power train warranty plan) [img]<<GRAEMLIN_URL>>/smile.gif[/img]
Wayne
Old 12-14-2011, 04:57 PM
</div></div>
I was concerned about this. When I break in my engine I'm going to run regular filters until everything get's past the hickup stage.
Since the black foam is so porous and allows everything past except a small bird I was also thinking about running a layer of flat filter material from K&amp;N or some other source underneath the black foam. Iwas thinking of taking one of their flat pleated filters and leveling it out and use this as filter base to catch anything the foam does not filter..which is plenty, plus keep out melted or deteriorating foam.
Old 12-14-2011, 07:05 PM
TheNovaMan TheNovaMan is offline
Send a message via AIM to TheNovaMan
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: pxtx</div><div class="ubbcode-body">I would run two small air cleaners on the street and nothing at the track. </div></div>
Running naked carbs at the track is not technically legal unless they're under a scoop.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: four speed</div><div class="ubbcode-body"></div></div>
What fuel hose and ends are those?
Just a heads-up. Carry on. </div></div>
Backfires are probably the majority of the problem, but I wouldn't rule out fuel incompatibility. Thanks to the EPA, today's gasoline is much harder on polymers than it used to be.
~Pete
I know enough to know that I don't know enough.
Old 12-14-2011, 07:08 PM
That should work very well. I cut down a large diameter velocity
stack and made a mini flyeye for my Dominator on my Chevelle. I did the same thing you are speaking of. We worked out the tune on the dyno and I installed the air cleaner after that. I've never had a problem out of the foam in all the years it has been on the car.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: whitetop</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: VintageMusclecar</div><div class="ubbcode-body">FWIW, re: those air filters with the black &quot;foam&quot; type filter elements;
</div></div>
Since the black foam is so porous and allows everything past except a small bird I was also thinking about running a layer of flat filter material from K&amp;N or some other source underneath the black foam. Iwas thinking of taking one of their flat pleated filters and leveling it out and use this as filter base to catch anything the foam does not filter..which is plenty, plus keep out melted or deteriorating foam.</div></div>
Old 12-15-2011, 03:24 AM
Future Stock Future Stock is offline
In the Washington DC area, alot of people ran the plastic rural newspaper tubes. I still have mine, it was from the evening &amp; weekend times.
