Old 01-12-2012, 10:59 PM
day2killa day2killa is offline
Default will these tires work for my day 2 project?
http://www.ebay.com/itm/Mickey-Tompson-I...=item2c620c9854
thanks in advance
john
Old 01-12-2012, 11:14 PM
whitetop whitetop is offline
Default Re: will these tires work for my day 2 project?
John
They look good, tread wear is even on both tires and the price is right. I would snag them for the $100 BIN.
Soft compound S/S is a mid 80's to current feature on M/T tires...S/S was not around in the 1970's.
That being said the tread/look etc is identical to the 1970's regular bias ply tire. Most people would not know anyway. I would put the white letters inside and/or paint them if you want to be more correct.
I also have a feeling the old style bias is going to come out again. M/T discontinue these tires and then bring them out again every so often. They have done this for the last 25 years.Almost as if they run a huge batch and then let them run out and repeat.
Old 01-12-2012, 11:50 PM
4onthefloor 4onthefloor is offline
They should work -These look older ..But I know the "S/S" moniker was used in the 1980's till just a few years ago,I used these type of M/T tires before and they wear out pretty qwick-But For the price -I would buy them &mount them on some Cool rims And see how it looks on your Car
1967 Firebird 496 BBC Stroker,M22 wide ratio,Thrush Mufflers
Keystone Klassic's with Big&Little's,High Jacker Air shocks.
Old 01-12-2012, 11:54 PM
These tires are worth the $100.00. They are not old. I contacted the owner and he said they are not very old and he put the white letters in and they got scoffed some. Email him and ask him questions. But, they are woth the 100.
Old 01-13-2012, 03:02 AM
bought the tires, thanks gentelmen for the advice, now i just need to get them,
also what size rim and backspacing would i use to keep these tucked in my chevelle?
Old 01-13-2012, 02:04 PM
69 Post Sedan's Avatar
Over at the Team Chevelle site they have a section for wheel sizes. The way it was explained to me is divide the width of the wheel in half then add a 1/2". An 8" wide wheel divided in half is 4" then add a half inch. 15X8 wheels with 4-1/2" back spacing work great.
Corvette rally wheels have a 4-1/4" back space. IIRC That's why they work pretty good on Chevelles.
Kurt
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 01-13-2012, 02:10 PM
those Mickeys I have on the back of my camaro are mounted on 15X7 Cragars with I think 3-3/4" backspacing. NO problems with anything except the right side tailpipe rubs. I use the 1/2" spacers for that. I also run air shocks with low air pressure.
Old 01-14-2012, 12:47 AM
mr.4speed mr.4speed is offline
mine are 15x8 4 1/2 bs L6015 MICKEYS FIT GREAT!
4 gear 4 life!
Old 01-14-2012, 01:31 AM
well there ya go day2killa! Just listen to the San Jose man! He is the King of MT tires.
Old 01-14-2012, 02:03 AM
Here's my car with factory 15 X 8 Corvette Rallys and 28 X 11.5 M/T ET Streets.
I did a little research and it appears the 15 X 8 rally's have a 4" backspacing not 4-1/4". So a 4-1/2" backspace would be better as mine are a little too far out although I don't have an issue with any rubbing.
Kurt
