  #11
Old 05-30-2012, 06:43 PM
kwhizz kwhizz is offline
Default Re: Next Years Power Tour Car
I had another "Nagging" problem that wouldn't seem to go away.....I have all Ride Tech suspension on the car.....I had the front end aligned three times and when turning a corner the car would lightly squeel the tires ......and the Castor never looked correct.....I had it aligned again yesterday and after pulling out of the shop.....same thing....Tires squeeling.......So......I call Mark Webster to see how his car steers....(66 Impala with suspension)......his car had no issues.....so...I explained what was going on with my car.....as he's thinking about it, he ask's me if I put the original GM bushings from the old control arms into the new arms.......I say what Bushings???......So....he explains that these Bushings take up the difference in the bushing hole and the ecentric bolt o.d., and the head thickness allows for the compression of the unit after setting to lock everything in place........
I noticed the clearance he was talking about when I put the front end together and checked the Ecentric bolt in the old arm and it was sloppy also, so...I didn't think any more about it.....I went home and got the old arms out and noticed that only one side had the bushings in it (obviously I checked the bolt in the one with the missing bushings).....that's why the tire on the original Nu Yawk survivor was chewed up on that side.....Those Crazy Nu Yawk repair guyz......So....I take the old bushings out and measured them and made some new ones.....the car was back at Frame-Up for some other fine tuning...So, Donny took everything apart and installed the "New" missing bushings.......Back to the alignment shop tomorrow......hopefully the problem will now be solved as the alignment will now be in a controlled condition.......All this with one day to spare.......Leaving Friday a.m. for Detroit and the start of the Power Tour..........
Bottom line......I'm glad I talked to Mark!!
