Old 07-09-2012, 01:45 AM
Camaro Don Camaro Don is offline
Default Re: 69 Camaro SS grill (which Black to use)?
Thanks Fred, thats out of my league though.
Old 07-09-2012, 02:09 AM
L78 Fred L78 Fred is offline
No Problem- best wishes!
Fred
Fred
[email protected]
610-585-4155
WANTED:
1969 396/375 hp JH Vin N6352xx Mid April 69 block 272 casting
Always looking for dated L78 parts from Jan-Apr 69
Old 07-09-2012, 04:23 PM
my70454ss my70454ss is offline
The grill is cast in bone. And yes they are quite expensive. I just bought an NOS grill for $1,800 for my 69 Yenko.
Rodger
1969 Fathom Green Yenko Camaro 4-Speed
1969 Garnet Red RS/Z28 Crossram JL8 4-speed ( Under Restoration )
Old 07-09-2012, 06:03 PM
bergy's Avatar
bergy bergy is offline
How about if some of the experts chime in here. I have an 05E '69 Camaro that I believe has the original grille in it. It is black plastic painted silver (fathom green car). I have pictures of it "as removed" if it helps.
Old 07-09-2012, 09:03 PM
Lynn Lynn is online now
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: bergy</div><div class="ubbcode-body">How about if some of the experts chime in here. I have an 05E '69 Camaro that I believe has the original grille in it. It is black plastic painted silver (fathom green car). I have pictures of it &quot;as removed&quot; if it helps. </div></div>
Well, first off I am a CNE (certified non-expert), but pretty darn sure the silver grills were all cast in off white for the assy line. I would suspect your grill was replaced.
Having said that, I have no doubt there are more than a few guys here that have much more experience messing with true survivor cars.
Old 07-09-2012, 09:04 PM
And another thing: I would not paint the grill with Krylon. About the only rattle can paint I would use ona an exterior car part would be SEMS brand.
Old 07-09-2012, 09:22 PM
bergy's Avatar
Sorry if I've offended you Lynn - sure didn't intend to. My car was never restored and pretty original, but certainly could have had the grille replaced along the way. I was just wondering if there was more then one supplier &amp; maybe different base material colors. A lot has been written about the colors of the finished grilles, but I haven't seen anything about different colors of the base material.
Old 07-09-2012, 09:58 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: bergy</div><div class="ubbcode-body">Sorry if I've offended you Lynn - sure didn't intend to. My car was never restored and pretty original, but certainly could have had the grille replaced along the way. I was just wondering if there was more then one supplier &amp; maybe different base material colors. A lot has been written about the colors of the finished grilles, but I haven't seen anything about different colors of the base material. </div></div>
Well, crap. One of the problems with the internet is that typed words don't always convey the spirit in which they are intended. I was not the least bit offended. Calling myself a certified non expert was only meant to convey acknowledgement of those on this board with considerable more expertise to me. Sorry if I came across as being whiney.
Old 07-10-2012, 02:13 AM
When I purchased a number of 3957062 black grills in the early 80's I believe the silver (3957044) was already discontinued- that is why I am confused about what I have and asked the question about the base material.At that same time 2 of the other grills I still have are marked VIP(on the box) which is what a number of the parts I have received are marked before they are discontiued as well as that designation was used for rush shipment which mine were not
I will take some pictures and post in the next few days, as I have stated earlier there are no marks or indications that it was ever bolted up or masked and sprayed. I opened the sealed box sometime in early 2000 +/- a few years and put the grill aside still in the original box.- maybe a factory screw up? or someone purchased it- did a hell of a job painting it and returned it?
Thanks
Fred
Fred
[email protected]
610-585-4155
WANTED:
Old 07-10-2012, 10:06 AM
bergy's Avatar
Pictures would help. Don's original question concerned what paint to use on his grille, but how much of the back side of the grille should he paint? The grille in my fathom green car was black base material and painted silver, but the back side is still mostly black. Many of the survivor cars that I have seen with the bone colored base material grilles have a lot of the bone color showing on the back side. It would be great if Steve and some of the survivor judges could chime in.
