Old 10-02-2012, 01:20 AM
BlackCherryLS6 BlackCherryLS6 is offline
Default Tires on 1970 Judge
Trying to find out what would be the original tire for my car. Looking at my build sheet box 106 it's says G70x14 2x4 WL FUYR. Below in the options codes it says PK5 G70x14 WL FG. Window sticker says PK5 G70x14 White LTR Fiberglass. So am I correct that it should be the Firetone Wide Oval tire?
Thanks
1970 Black Cherry LS6 Chevelle
1970 Orbit Orange GTO Judge
2013 Summit White Nickey Stage II ZL1 #006
Old 10-02-2012, 02:16 AM
Default Re: Tires on 1970 Judge
This is a 10A Pontiac built judge Conv original spare tire.
I've got the build sheet around here somewhere, let me see if I can find it and see what it says.
Old 10-02-2012, 02:57 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: firstgenaddict</div><div class="ubbcode-body">This is a 10A Pontiac built judge Conv original spare tire.
</div></div>
If you can find the build sheet to verify that would be great! Thank you.
Old 10-02-2012, 11:42 AM
Tracker1's Avatar
Tracker1 Tracker1 is offline
when was your Judge built?
Old 10-02-2012, 01:26 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Tracker1</div><div class="ubbcode-body">when was your Judge built? </div></div>
March in Fremont,CA
Old 10-02-2012, 02:04 PM
Build date was 02-24 and ship date was 03-03-70
Old 10-02-2012, 02:22 PM
Tracker1's Avatar
For that date at that production plant you could have gotten any of three tires - Uniroyal Tiger Paw, Polyglas GT or Firestone Wide Oval - either would be correct.
Old 10-02-2012, 08:57 PM
Since Firestone and Goodyear are both options for my car I'm leaning towards the Firestones since that is what was pictured in the 1970 brouchure. Thanks for the help guys!
Old 10-02-2012, 09:19 PM
SS427's Avatar
SS427 SS427 is offline
That and they are not as commonly used as the Goodyears so it is nice to see something a little different once in a while.
Rick Nelson
Old 10-03-2012, 12:18 AM
Do they make the small letter Firestone wide oval?
Survivors, restored cars, &amp; other photos
