#11
Did you use a standard spring compressor the way pictured here?
Works good on just about any car. Remove the top hook block and only use the threaded bottom block. Slide the shaft through the shock hole and screw on the block and hooks. Simply slide the spring over the tool and use the top shock mount to compress the spring. Took me about 5 min. per side. <div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: motionwannabe</div><div class="ubbcode-body">Thanks for the info. I just completed the 5lug spindle change over and front suspension change on ours. Isnt it a blast putting the coil springs back in?? I thought it was miserable. <div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Hemicolt</div><div class="ubbcode-body">Fronts are 15 x 4.5 wide. Tires are Pro Trac 560/15. http://www.cokertire.com/560-15-pro-...nt-runner.html If you look at the Todds red car here https://www.yenko.net/ubbthreads/ubbt..._no#Post504889 ,you can see the same size tire on the car. <div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: motionwannabe</div><div class="ubbcode-body">What size Cragars and tires do you have on the front? I have 15x8 Cragars with H50 Mickey Thompsons on the rear of my Vega. I just bought a set of F-70-15 Mickey Thompsons for the front . Just trying to figure what width and height tire works well.Thanks for any advice you can lend my way. </div></div> </div></div> </div></div>
It's not the critic that counts, not the man who points out how the strong man stumbled or whether the doer of deeds could have done them better... |
